TxAgfisher wrote:I went sans headliner...
corefile wrote:TxAgfisher wrote:I went sans headliner...
@TxAgfisher where did you put the rear headphone jacks - don't see them in the pic you posted. Trying to figure out where to put mine if I don't put a side panel back there
mtv wrote:Bagarre wrote:Not for the weight. The foam and felt probably weighs just as much as a light wool headliner.
Not for the noise. That's what headsets are for. Plus the foam deadens just as well as a headliner.
Not for the warmth, Unless your headliner is vinyl, you're not sealing anything. Cold air from leaky gaps goes right through wool headliners.
Not for the utility. It adds no utility. It's simply a method of covering what's over your head.
I did it because I think the wool headliners look antiquated and they are a royal SOB to install right.
Felt over foam looks very nice. It makes a clean install. One benefit is, it gives me a little more headroom.
I might feel differently if I got my driver's license in a Studebaker but the wool headliners make the airplane look old.
That's ok if you like the old look. There is no better or worse. It's simply two options of equal value with different aesthetics.
Now you’ve gone too far......let’s not be putting down Studebakers, okay?![]()
And, I’ve installed two wool headliners, and thought they were fairly easy. They shrink nice to remove wrinkles with hairdryer.
But, again, it’s whatever turns your crank, I reckon. Cept when it comes to Studebakers, that is![]()
corefile wrote:For those that have gone the foam route and have the rear seat shoulder harness attachment strip of aluminum that spans between the two bulkheads on the ceiling - how did you handle that?
