Backcountry Pilot • Tow bar for Airglas Fork?
5 postsPage 1 of 1
Is there a tow bar that works with the Airglas nose fork?
Hoeschen offline
Aircraft: 1956 C182, 2014 RV-9A
Re: Tow bar for Airglas Fork?
It's been about 20 years since I owned a nosewheel airplane, but I seem to recall that the towbar for these generally grabs ahold of a set of lugs above the nose fork itself-- not the axle nuts like a tailwheel towbar. So shouldn't a towbar work on both the wide fork and the standard fork?
Same towbar should work - At least it does on the 205. As Hotrod says it fits a separate set of lugs.
Flynengr
flynengr offline
You have to replace the bolt that goes crossways through the block on top of the fork. Install a longer bolt with bushings and then your towbar will fit. I'll tryto get some pictures.
Jeredp offline
Aircraft: Cessna 172
We're doing the same as the above. Smaller bolt through the top block, with bushings, to allow the original tow bar (or any other for a Cessna) to fit.
You can see the bolt hole through the block in this photo:
5 postsPage 1 of 1
