Backcountry Pilot • Transporting and disassembling float advice
27 postsPage 2 of 21, 2
Re: Transporting and disassembling float advice
Thinking about it a little more, I am now wondering if i should have removed the 5 screws and 6 bolts to remove the two plates on the inboard and outboard side of the float to take the spreader bar out?
https://imgur.com/a/CJMqlLk
How easy do these come off? I would be hesitant to pry it with something for fear of damaging the skin.
cdnbrewer offline
Aircraft: 1979 172 XP (R172K)
Call these folks. Request their advice. Best in Ontario. Even if you can pull the permit yourself, don’t. Let these people do it for you, and coach you on how to stay safe and in compliance.
http://www.diamondplusspecialized.com/services.php
Pinecone offline
cdnbrewer wrote:Thinking about it a little more, I am now wondering if i should have removed the 5 screws and 6 bolts to remove the two plates on the inboard and outboard side of the float to take the spreader bar out?
Those are the “clamshells” I was referring to in a previous post, definitely want to remove those if you’re pulling spreader bars.
Halestorm offline
Aircraft: C-182E Pponk
Halestorm wrote:Those are the “clamshells” I was referring to in a previous post, definitely want to remove those if you’re pulling spreader bars.
When the floats go back together, what’s the best grease/etc to use on the spreader bars to make it easy to pull them apart next time?
Chris
airChris offline
Chris
EDO specifies Dubois ACG-2 waterproof lithium grease, it’s very good stuff.
With the Kenmore line planes we’ve been using TefGel with good results for several years.
Halestorm offline
Halestorm wrote:With the Kenmore line planes we’ve been using TefGel with good results for several years.
Do you use TefGel just on the bolts, or do you also coat the spreader bar with it where it contacts the clamshells?
Chris
airChris offline
scottd170 wrote:Hi
I’ve transported my 2870’s many times over the roads here in Maine. What I did was modify my snowmobile trailer with two full length 4x4s. I routered down the center of the 4x4 s to accept the keels of the floats. Lay the boards on the trailer and slide the floats on, a little water on the boards helps them slide. Once they are loaded I run some sheetrock screws up through the bottom into the 4x4 s to keep them in place. Strap the floats to the trailer and you’re ready to go. You can also go to the hardware store and get a “wide load” tape to put on the front of the vehicle. You can also get a wide load permit from the authorities if you want. Once you do it the first time it will be easy to do it again and again.
I believe the 2870s are larger than the 2400s so you shouldn’t have a problem. Most states have a ten foot wide limit. My 2870s hang over the sides of the trailer but have never had any problems. And a lot easier than disassembling the floats. Hope this helps.
Scott
I know a guy who moved a pair of 2960's on a Uhaul trailer with 2X8's strapped across it from Prince Albert, Saskatchewan to Hibbing, MN. No permit, no extra lights, just a pair of red bandannas zip-tied to the water rudders. Didn't have a router to create the grooves for the keels, but a handsaw and a chisel worked just fine. 850 miles and only saw one Mountie and that was at night and he was going the other way. Customs guy had no idea what they were, but gave me no problems. Smart? Maybe not. Successful? Absolutely.
Henny offline
Aircraft: Cessna 185C Skywagon,
de Havilland DHC-2 Beaver
