Backcountry Pilot • Transporting Floats
Transporting Floats
12 postsPage 1 of 1
Transporting Floats
I need to get a set of 2440's from Hamilton, Ontario to Winnipeg, Manitoba. Can anyone suggest the best method to get them here (other than attaching them to the plane) They are approximately 10'6" wide so putting them on a flat deck would constitute a wide load unless they were propped up on one side. Other option is to put them up on an angle in an enclosed semi-trailer.
If anyone is aware of a specific company that does this? Any names would be appreciated.
thx.
garth
gear offline
Re: Transporting Floats
Pull the spreader bars and rigging off, throw it in the car/pickup...put them on top, strap them down and drive home. Nothing to it...done it dozens of times. You need to be pulling all that and inspecting attach points, hardware, etc before they go back on a plane anyway.....especially the saddles for the spreader bars (very common place for corrosion of the aluminum as well as the clamping bolts).
hardtailjohn offline
I've heard that you want to avoid taking apart the assembley? As it a big beal to get everything set up again and re-rigged? (Being new to floats - I don't know this, I've only heard it)
thx.
g
gear offline
Just be sure to mark all the tension rods and flying wires so they go back in the same place they came from and the rigging will be OK, And yes they should be taken apart every so often to inspect, clean and lube the parts. Broken down this way they will transport real easy on a rack on a pickup truck or small trailer.
shorton offline
Aircraft: Stinson 108-2
John is right, just dissassemble the spreaders and vertical struts, strap em on and go home. Don't worry about reassembly. The only thing that's adjustable is the diagonal brace wires, and you need to re-rig those every time you install the floats anyway. They had to be loosened to get them off the plane, anyway.
And, John is absolutely correct on the note to look carefully at all this stuff for corrosion. I've seen floats that hadn't been disassembled for years, just removed and parked on the bank, and they had serious filiform corrosion in all the blocks. Dissassemble them every couple seasons inspect them, and lube them well with new bolts, etc when they go back on the plane.
I have seen boat trailers set up with bunks to accomodate the floats, holds the struts and cables and all the parts. Makes it easy to move your floats to and from each season. Might be worth the investment.
RanchAero offline
1976 Maule M5-235C
Hello gear,
I am coming to Winnipeg tomorrow (Tuesday 17th) and would like some advice on something I am looking for. I will PM my e-mail address. Thanks Steve
steve offline
Aircraft: 1980 Cessna 185F
These guys haul stuff for us every day out of WPG you might give them a call
Searcy Trucking Ltd.
1470 Chevrier Boulevard, Winnipeg MB, R3T 1Y6
Phone: (204) 475-8411 Fax: (204) 475-2466
Toll-Free: 1-800-665-8411
mr scout offline
Thx. for the info guys. I'll make arrangements to break down the floats.
We have an account with Searcy so I'll give them a shout.
thx.
garth
gear offline
Garth, I thought you just bought a Stinson with 2870s, whats the 2440's for ?
Rhyppa offline
Rhyppa wrote:Garth, I thought you just bought a Stinson with 2870s, whats the 2440's for ?
Stinson deal did not get finalized - instead bought a Maule M5-235 with 2440's. Going down next week to Adventure Seaplanes in Florida for my float endorsement so I'm pretty excited.
garth
gear offline
Heres how I moved a set of CAP 3000's from Sudbury to Sault Ste. Marie years ago. I just layed some 2x6s across the box, set the floats on them and strapped them down. Red flags on the rudders. It went well, but it was hard to open the driver's door wide enough to get into the cab.
nofate offline
12 postsPage 1 of 1
