I'll see what I can do. I'll be home Monday and try to scan it. If I have time Monday I'll make some copies. I don't remember where I picked that up... I searched the Nav Canada website and don't see it available now.
Keith
Zzz wrote:Might be able to autotrace it to generate a vector based PDF but that JPG version is high res enough to print.
There's nothing special about an image embedded in a PDF. The size and printed quality will be the same unless it's been traced to a vector format, and even then you're only as good as the data you start with.
Would be nice to find a better copy of the original map.
