Backcountry Pilot • Tyre pressure for rough strips?
7 posts • Page 1 of 1
Cessna 182, stock sized tires, I ran tire pressure according to the POH 49 front , and 42 psi in the mains.
Some of the strips I go to have mud, others are a bit rough.
Was thinking of lower the air pressure in the mains, recommended or not?
motoadve offline
Aircraft: Cessna 182P
CJ 6 Nanchang
Cessna 170B
Re: Tyre pressure for rough strips?
I don't know about a C-182, but in an Ercoupe, C-150, and my current C-172 I run 10 psi less than the book spec for gravel operations. It makes the bumps a bit smoother, but adds a slight but noticeable increase in takeoff distance.
Dale Moul offline
Dale
Gravity Strikes Again.
I'm guessing that's a typo when you wrote "42 psi in the mains" and you mean 24 psi?
Edit: I just checked the 182 POH and 42 psi is right. Wow, that is hard! But I guess it's a 6.00x6.
Yes it is hard and they are 6 x 6.00.
I guess 10psi less wont do any harm .
motoadve offline
CJ 6 Nanchang
Cessna 170B
Moto-
You need some tires...seriously...
With all that flying you do and the muddy strips, those 6x6 are an insult to your missions. :lol:
I know you are aware of this.
AKT
Yes Im totally aware.
motoadve offline
CJ 6 Nanchang
Cessna 170B
I drop mine way down sometimes, like 25 but I carry a little 12 volt compresser to reinflate. Takeoff roll is ridiculous on asphalt that way, so figure 1.5 times your usual. On my j model, I also found out the hard way how important it is to zip tie the braided steel brake lines to the gear legs. I broke both brake lines once right where they go from braided to solid because of the violent flopping on a rough strip. Almost got to the barbed wire fence on that one.
Nosedragger offline
