Backcountry Pilot • UBG-16 CHT
UBG-16 CHT
12 postsPage 1 of 1
UBG-16 CHT
Can I yank my original CHT gauge in the 182B if I install a EI UBG-16 with all six CHT monitored. Be nice to open that space for somthing more usefull. Maybe Matt at EI can chime in on this. Had a good phone conversation with him this afternoon and forgot to ask him about it.
Re: UBG-16 CHT
If it is part of your original equipment list then no you can't remove it. You can piggy back or put the probe in a different location but you can't remove an original CHT gauge.
Bill
Green Hornet offline
AKA SOJORRN
1997 Maule-M7-235C
I am a leaf on the wind watch how I soar! Hoban "Wash" Washburne, Firefly/Serenity
WOC SPOT
Re: UBG-16 CHT
Thought that some of their stuff was counted as a replacement but maybe not this. I can just move the original guage to some out of the way place (like the back seat).
Re: UBG-16 CHT
I liked the comparison between the UBG-16 and the original equipment. There is quite a delta between the two.The good news is that the CHT & EGT do not get as hot as the original gauges indicate. I also added Oil temp, here again lower than original gauge and OAT which gives me the warm and fuzzies on cold days.
How is the hobby shop going? :mrgreen:
AKA SOJORRN
1997 Maule-M7-235C
WOC SPOT
Re: UBG-16 CHT
qmdv wrote:Can I yank my original CHT gauge in the 182B if I install a EI UBG-16 with all six CHT monitored. Be nice to open that space for somthing more usefull. Maybe Matt at EI can chime in on this. Had a good phone conversation with him this afternoon and forgot to ask him about it.
Yes, you can. I did just that with my 182, although I used the US8-A, the non bar graph model. I believe the UBG-16 is STC'd as a primary replacement, if so you remove your factory CHT and EGT. Would be hard to believe the newer model wouldn't be STC'd as a primary replacement.
Bonanza Man offline
Re: UBG-16 CHT
You better talk to EI because they were the ones that told me no if it is on your original equipment list! They gave me a piggy back probe because the CHt could not be removed.
AKA SOJORRN
1997 Maule-M7-235C
WOC SPOT
Re: UBG-16 CHT
Green Hornet wrote: How is the hobby shop going? :mrgreen:
Plane is in the hobby shop. Finished the doors this morning. I am soooo excited. Nipples haven't been this hard since the Craftsman sale at Sears last year. :lol: :lol: :lol:
Will talk to EI. One of those guys reeds this forum. Maybe he can shed some light? [-o< [-o<
Re: UBG-16 CHT
Finished the doors this morning. I am soooo excited. Nipples haven't been this hard since the Craftsman sale at Sears last year. :lol: :lol: :lol: [-o< [-o<
Man, do I envy your way with words! :lol: =D> :mrgreen:
AKA SOJORRN
1997 Maule-M7-235C
WOC SPOT
Re: UBG-16 CHT
qmdv wrote: I am soooo excited. Nipples haven't been this hard since the Craftsman sale at Sears last year.
Hahaha. I know what you mean.
Re: UBG-16 CHT
Tim the guy from EI on the forum is Mathew Sharp ( user name). Just PM him he is a great guy with a lot of knowledge.
AKA SOJORRN
1997 Maule-M7-235C
WOC SPOT
Re: UBG-16 CHT
Tim Here is the stc
UnitedStatesofAmerica
DepartmentofTransportation_FederalAviationAdministration
SupplementalTypeCertificate
Number SA00680SE
This certificate, issued to Electronics International
63296 Powell Butte Highway
Bend, OR 97701
certifies that the change in the type design for the following product with the limitations and conditions therefor as specified hereon meets the airworthiness requirements of Part * of the * Regulations.
Original Product⎯Type Certificate Number: *See attached FAA Approved Model List (AML)
Make: No. SA00680SE for a list of the approved airplane
Model: models and applicable airworthiness regulations.
Description of the Type Design Change: Installation of Electronics International Inc. Model UBG-16, or UBG-16T bar graph engine analyzer in accordance with Electronics International Inc. Master Drawing List MDL 1111982, Revision “NEW”, dated November 11, 1998, and Installation Instructions II 1111981, dated November 11, 1998, or later FAA approved revisions.
NOTE: The UBG-16 and UBG-16T listed here are designed as advisory engine analyzers, and are not to be used as primary engine instruments.
Limitations and Conditions: Approval of this change in type design applies to the aircraft models listed on the AML only. This approval should not be extended to other aircraft of these models on which other previously approved modifications are incorporated unless it is determined that the relationship between this change and any of those other previously approved modifications, including changes in type design, will introduce no adverse effect upon the airworthiness of that aircraft. A copy of this Certificate and AML No. SA00680SE must be maintained as part of the permanent records for the modified aircraft.
If the holder agrees to permit another person to use this certificate to alter the product, the holder shall give the other person written evidence of that permission.
This certificate and the supporting data which is the basis for approval shall remain in effect until surrendered, suspended, revoked, or a termination date is otherwise established by the Administrator of the Federal Aviation Administration.
Date of application: November 12, 1998 Date reissued: July 8, 2005
Date of issuance: March 10, 1999 Date amended:
By direction of the Administrator
__________________________________________ (Signature)
Acting Manager, Seattle Aircre
aft Crtification Office (Title)
Any alteration of this certificate is punishable by a fine of not exceeding $1,000, or imprisonment not exceeding 3 years, or both.
This certificate may be transferred in accordance with FAR 21.47.
mr scout offline
Re: UBG-16 CHT
GMDV
You just might end up preferring your original CHT gauge, especially if it is analog.
The reason is RESOLUTION.
I have one of the engine analyzers where it is rather easy to determine the EGT, but the CHT leaves a lot to be desired. The CHT bars on mine are embedded down on the bottom within the EGT bars. The best I can do with them is to tell if one of the Cylinders were to go WAY our of wack. While the analog gauge that came with the 180hp conversion to my 170 is only on one cylinder. It is my ASSUMPTION, I know, that it was placed on the inherently hottest cylinder. I still keep an eye on that one for CHT changes since I can actually see if and when the needle is moving or moved.
So far, so good.
This is only presented as my subjective position.
It may be that I have never learned how to use the damned CHT section.
Chris C
wannabe offline
53 C-170-B+
12 postsPage 1 of 1
