I have read about the dreaded base to final turn stall/spin repeatedly, and decided to try to do the stall portion on purpose to see how my 182E acted. I was hoping to learn this portion of the envelope well enough to recognize it in real life before it bit me. I took my 182E up to 4000 ft AGL and set up my standard descent, 500 ft per min and full flaps. Then I slowed it down to about 60 knots and turned left, banking 45 degrees, and kept the same back pressure. Result: no stall buffet, no warning horn, mild nose drop and speed increase, VSI showed 1000 down.
Second try, same setup, 50 kts, same turn, keep back pressure, essentially same result. Third attempt, 45 kts, 45 deg turn, try to keep the nose up, no buffet, no stall warning horn, but 1500 down on VSI.
I practice level slow flight, falling leaf, and trim (go around) stalls, and this felt nothing like those. My stall warning horn was working on several landings that day.
I was careful to stay coordinated and ready to drop the nose, not wanting to have to use spin recovery techniques, but I was surprised by the apparent mush instead of stall. Is the stall/spin scenario just much harder to get into than I thought, or is the mush with high descent rate what is getting called a stall/spin?
The rest of my ramblings are probably stuff YOU already know, but someone else reading this may not, and therefore decide that their airplane really is 'unstallable'.
