More than just comfortably above the obstacle is an unnecessarily steep climb. With 17,000 hours below 200' AGL and 11 engine failures there, I am still alive because I always had cruise airspeed for maneuvering or was already zooming up. Always from low ground effect, either over the runway or crop row, I entered maneuvering flight at cruise airspeed with or without engine thrust.
So many fall from too low to recover from stall, most with the engine running well. A really good pilot did so recently with a turboprop on a light airplane. Demonstration of how steeply a STOL airplane will engine climb, not zoom climb, is fine above 1,000' AGL. Demonstration of how a STOL airplane will almost hover out of ground effect is fine above 1,000' AGL. With a really capable airplane in a pilot's choice situation, it need not be life or death. Most trainer airplanes are actually STOL capable when flown using good STOL techniques, but luckily they are not capable of extended dangerous pitch attitude engine climb. Even more fatalities would occur from falls from higher up but not high enough to recover.
Few crop dusters or gunship pilots die that way because the climb up is a high airspeed zoom climb and there is a planned, steeply banked, return to target with the wing unloaded. There is neither load factor nor stall at 1g. Stall can only happen if the pilot is pulling back on the stick. The critical angle of attack is when stall happens, not what causes stall. Utilizing the law of the roller coaster, really aggressive maneuvering flight can be safely flown, demonstrated, or just enjoyed.
The difficult sell is convincing pilots to fly reasonably fast when out of ground effect but too low to recover from stall. We should enter maneuvering flight as fast as possible. The air police will not arrest us for staying in low ground effect until cruise. I have taken off that way about 8,500 times. Money in the bank doesn't start until 1,000' AGL. Don't spend all the money in your pocket trying to get to the bank hurriedly. In maneuvering flight we need to be quick, but not hurried. Slowing, on the other hand, decelerating on short final going into ground effect is fine.
An excellent example of what I'm trying to teach here was demonstrated by Dan Gryder last week. He was making a low pass over a STOL strip they had just set up. He was with the owner in his C-150 and had approached with full flaps. On the go around, the flaps were stuck down. Dan refused to pull up on the yoke and stall. Rather, he traded the potential energy of his 100' altitude for needed extra airspeed in his turn away from obstructions and to line up with the tall corn rows where he closed the throttle and landed. As any crop duster knows, tall corn inverts all who enter (with little damage.) Dan didn't have cruise airspeed, but he had some margin above Vso. Rather than insist on maintaining the 100' altitude, he traded that altitude for extra airspeed to turn without stalling (90 degrees heading change not 180.) Good energy management Dan.
