Backcountry Pilot • UPDATE 9/29 -My Cessna 180 Project - She is Flying
268 postsPage 10 of 141 ... 7, 8, 9, 10, 11, 12, 13, 14
Re: UPDATE 9/4 -My Cessna 180 Project- HOW MUCH WILL SHE WEI
I'm in at 1801. Don't figure survival gear in on the empty wt.
dirtstrip offline
1906#.... you need to fly today and get that thing cleaned off in the rain .
low rider offline
vail
1922#
AKclimber offline
1815#
Looks great in the video clip, the spinner is remarkable!!
Sig220 offline
I weigh airplanes so I have little advantage bare airframe with 2 seats , pponk 3 blade,no fuel - depends on amount of radios ,tires , interior etc. I'd guess 1645 empty .
182 STOL driver offline
I think he's trying to distract us with a shell game. ;-) But it's fun, so I'll play:
5000#
:D
1727# =D>
Great looking bird!
4Whitey offline
I'm going slim: 1707#.
Looks fun Kevin, I can't wait to hear the first impressions.
Early 180's are the hardest to guess weight on. I know of several examples that have a 'real' weight in the high 1500's, we've all seen examples that weigh in the high 18's... and people wonder why I try and watch the weight... Pponk or not 300#s makes a huge difference.
There is an operator in the McCarthy area that has a '53 set up very much like yours, except it has been on an extreme diet... I have seen that plane where most cub drivers wouldn't go :wink:
Not sure what change the later model cowl / exhaust etc made, and not sure which flavor of Ti gear you have, but I would guess you'll come in around #1795. I'm probably underestimating since you have hydraulics, and IFR gear...
Don't be disappointed at the outcome, as many have said, it will almost certainly weigh more than you expect.
Take care, Rob
Rob offline
182 STOL driver wrote:I weigh airplanes so I have little advantage bare airframe with 2 seats , pponk 3 blade,no fuel - depends on amount of radios ,tires , interior etc. I'd guess 1645 empty .
You could make a good living weighing airplanes here in Alaska, BIll. :D
gbflyer offline
Kevin,
I thought you were going with the LE exhaust... from the video I see what looks like identical to my '57 2 into 1 stock exhaust? did you change your mind or is that a later add-on?
Darinh offline
Darin H.
KOGD
UPDATE 9/4 -My Cessna 180 Project- HOW MUCH WILL SHE WEIGH?
1797
Barefootsailing offline
You never said how many cans of spray paint you used to touch up certain areas my guess is 1754
bloomah offline
1835??
kevbot offline
I'm guessing 1770#.......Looking awesome Kevin.
Flynengr
flynengr offline
I gonna say 1922 lbs!
Jeredp offline
Aircraft: Cessna 172
Today was a REAL good day...except she did not take to the air... #-o
She did however fire up like a brand new engine and purrrrrred like a kitten. Man she sounds good. Had a small leak but that was due to a loose fitting that was not tight and she even got weighed. The only reason we did not fly was due to the VERY HEAVY WIND and thunder storms in the Sierra's today. Currently raining hard as I type this.
Here is my day...cowling and all fluids in (including the unusable fuel)
Getting weighed along with new ARM, DATUM, etc.
Whats that little blue box going to say? :roll: :roll: :roll: :lol: (Sorry SOY...its like the shell game :D )
Here you go.....drum roll pleeeeeease....
With the MT prop she will be under 1800# we are assuming...Anxious to see how much she will weigh with that prop and spinner...
So having not gone back through here...who is the winner on the weight game?
And then...she was rolled out of the hanger... =D> =D> =D> and I of course told myslef... [-X [-X [-X and then became very :cry: :cry: :cry: as it was blowing so hard across the runway...we pushed her back into the hanger...
Pretty fired up to say the least....
Yes Brian...I will be flying with you guys NEXT weekend! This weekend I will be doing circles around the airport very low to the ground at full throttle for as many hours as my tail feathers will take for the break in process...
To answer another question, I kept my exhaust (per Steve Knopp's request) as he said mine was in great shape and to spend the money on gas.
AKT
260Driver wrote:1825 [-o<
I believe 260Driver is the winner, off by 1lb. !
Re: UPDATE 9/5 -My Cessna 180 Project - The weigh in!
Just to add to this...My old allowable weight was 2550 before the Wing X....ITS NOW 3000 lbs!!!! :shock:
That means with 91 gallons of fuel (full) I am still going to have 774 lbs to work with...I never fly with that much gas unless its Alaska bound
AKT
What were the rules? Closest without going over? Think my 1820# was it then? Jeremy was close, would have been cool if he shacked it, he was pretty damn close.
Fingers crossed for some nice wx for you, gotta see that thing go!
Vick offline
Solum Volamus
