DonC wrote:I remember the airport description for Speravon in Alaska. Successful go around unlikely
if you look at the approach plate, and it says Cape anything.....don't go.
mtv wrote:DonC wrote:I remember the airport description for Speravon in Alaska. Successful go around unlikely
Yep, that ones a beaut......went in there once with a 185. I don't think taking a C-130 in there would be much fun on a nice day....
DonC wrote:mtv wrote:DonC wrote:I remember the airport description for Speravon in Alaska. Successful go around unlikely
They had a C130 crash there in the 70's Killed 7. Think it was between 30 and 45 deg up slope.
mtv wrote:Barnstormer wrote:Lot’s of times uphill landings are one-ways, so the landing is happening no matter what. Good news is the landing is up hill so speed will bleed off quickly. Don’t try and turn a one-way into a go-around, land the plane.
If it’s uphill on the side of a mountain there will be no horizon to visualize the glide slope so “visual cues” that some might use on a flat strip won’t work here.
Forget about trying to flare the landing, do that and at best a very hard landing will occur. It only gets worse from there.
Thinking anything “ground effect” uphill shouldn’t even be a consideration. Uphill trumps ground effect in landing.
Phil,
Mostly good advice, but.....Just to be argumentativewatch your own videos, and note carefully that indeed you flare quite noticeably on both landings.
Also, in a slatted airplane, you're already at a very high AOA on short final, compared to more "normal" airplanes, which means your plane is already close to matching the slope. Try that short final attitude in something without slats and you'll have a much more interesting landing, and that increased AOA puts your plane (at ~ 28 degrees vs ~17 degrees for a conventional wing) much closer to matching the slope while on approach.
But with a "conventional" (non slatted) wing, you fly into a slope, flare rather dramatically to match the slope, add power and land. Without the flare, it would be called a "crash", perhaps severe. You must get the airplane into a landing attitude with reference to the surface you're landing on, or a nose over or worse will occur.
And, as you rotate to match the slope, power helps to arrest the "descent" or rather the forward momentum, as you touch. And the ground effect that was mentioned earlier also helps, though as you say, it's not something you really control. But it's there, helping to soften the "arrival".
Good videos in any case, these things may be more noticeable than they are from the cockpit, as ones sphincter tightens.......![]()
