Ya gotta love the "Dude"
My favorite movie
T
CamTom12 wrote:Tested it today on the #4 bottom and #2 top plugs.
The first 2-3 threads from the ground strap are totally useless for grounding. Totally covered in deposits. After that, I saw a 0.9 ohm resistance from the ground strap. I saw the exact same number at the bottom of the copper gasket. Saw the same numbers on both plugs and both ground straps on each. I got my resistance values from the thread face opposite the ground strap since that's the part that would be in contact with the head threads.
The same resistance means there's not really any propensity for one path to be taken over the other.
So it looks like it's a toss up. Probably goes both ways randomly or something like that.
CamTom12 wrote:I heard good reports - some folks thought they even had a power increase. I figured that the further I could get the spark into the chamber the better, for both anti-fouling and for making power.
Sent from my LG-D850 using Tapatalk
mtv wrote:CamTom12 wrote:I heard good reports - some folks thought they even had a power increase. I figured that the further I could get the spark into the chamber the better, for both anti-fouling and for making power.
I used the long reach plugs for years on Lyc O 360s, many of which are prone to lead fouling. And, those engines generally are not approved for auto gas.
The long reach plugs work great and stay cleaner longer. I've run 360s that needed plugs cleaned every ~20 hours with standard plugs.
I've also run fine wires, but the long reach actually work as well or better.
soyAnarchisto wrote:I certainly can be (and am often) wrong - but I thought it was more about getting the right torque - and a copper washer gives a better seal with lower torque values. I dunno. I'm pretty sure ll those threads when tightened are making a pretty good ground connection to threads in the case.
soyAnarchisto wrote:Why do I have to use a copper gasket in the oil screen of my small continental? Is it conductivity or resistivity? It could also be impedance since there might actually be an imaginary component.![]()
Let me tell you something, pendejo. You pull any of your crazy shit with us, you flash a piece out on the lanes, I'll take it away from you, stick it up your ass and pull the fucking trigger 'til it goes "click."
- de jesus
Bingo.
8GCBC wrote:I have (2) boxes of 100 new copper gaskets for sale. I decided not to follow any advice from the engine manufacture and use dirty, bent, torched gaskets.![]()
Actually, maybe not.
Zzz wrote:8GCBC wrote:I have (2) boxes of 100 new copper gaskets for sale. I decided not to follow any advice from the engine manufacture and use dirty, bent, torched gaskets.![]()
I feel like you've chosen the silliest and simplest of false dichotomies to make your stand. The best thing about new gaskets is their shininess. I will not downplay the horror of torched and quenched copper though. It looks hideous against fresh clean Lycoming grey.
8GCBC wrote:Zzz wrote:8GCBC wrote:I have (2) boxes of 100 new copper gaskets for sale. I decided not to follow any advice from the engine manufacture and use dirty, bent, torched gaskets.![]()
Its a Service Instruction. Good luck with your mags! Hope it works out.
