Jaerl wrote:Food coloring and gas or water and gas? Both do the same thing. You guys do what you want but these testers take maybe 10-20 seconds to use. You need a sump checker in your plane anyway and I always carry water in my plane so I already have everything I need. Seemed like a good idea to me.
I use the same tester that you posted. I have a 50 gal tank in my pickup, so the alcohol test happens at the gas station. Sometimes water is not easily available.
That little tester needs to be held in one hand while trying to get somewhat close to the right amount of gas from the pump nozzle. The 1/2 ounce of gas you are trying to get usually ends up being a cup full, with gas running down your arm.
The tester works and it's not really that big of a deal to get it done.
If the food coloring works, just about any container that won't tip over would work.
And you won't smell like gas the rest of the day.
