Backcountry Pilot • Valve Lapping 0-470-50 p ponk
1 postPage 1 of 1
Hoping someone could suggest a shop that has experience doing this procedure. I’m located in Coeur D’ Alene and my mechanic has not performed this procedure in the past. Any suggestions within the Pacific Northwest is appreciated. I received the below guidance from savvy after I sent them the Borescope images of my p ponk.
Here is valve lapping information (from Paul New's website):
https://www.tennesseeaircraft.net/2011/ ... e-lapping/
1. Remove rocker arm, rotocoil (for Continental), and valve springs.
2. Check for excessive wear in valve guide.
3. Apply valve grinding compound to edge of valve, working down through the top spark plug hole.
4. Attach a small piece of clear vinyl tubing to the valve stem using a small hose clamp.
5. Attach a piece of wood dowel rod to the other end of the vinyl tubing.
6. Chuck the dowel rod into a cordless drill.
7. Rotate the valve with the drill while pulling the valve carefully back against the seat, alternating in both directions.
8. If the valve starts to "chatter," stop immediately... time for more grinding compound... might take 30 seconds or more.
9. Examine the valve edge through the top spark plug hole before adding more compound. (Be sure bottom spark plug is removed, and wash the valve edge off, letting the fluid and compound run out the spark plug hole.). I use Avgas in a squeeze bottle with a 90 degree spout for washing the valve edge, but I'm sure there are other options, like an appropriate spray solvent.
10. After each lapping cycle and subsequent washing of the valve edge, you can clearly see the progress, or lack thereof.
11. Repeat the process until you have a nice uniform band of sealing area on the valve, OR, you determine the valve cannot be saved.
12. If it was successful, wash the cylinder out as well as possible, and spray some lube in the cylinder for piston ring lubrication.
13. Reassemble everything, and do a gound run.
14. Check for leaks and do a compression test... hopefully it came up quite a bit!
[email protected] offline
Aircraft: 182 Q P-Ponk
1 postPage 1 of 1
