AvidFlyer wrote:I can't comment on them on the tab itself but I also noticed a huge difference when I put them on the bottom of my horizontal. I used to have a pristine 182 that hangared with us and it had the VG's on the top of horizontal. The other day I saw him sanding on his tail. Turns out the airplane went through 5 annuals before anyone realized they were on wrong all that time. Wonder what he paid for that snafu.
AvidFlyer wrote:I used to have a pristine 182 that hangared with us and it had the VG's on the top of horizontal. The other day I saw him sanding on his tail. Turns out the airplane went through 5 annuals before anyone realized they were on wrong all that time. Wonder what he paid for that snafu.
Battson wrote:AvidFlyer wrote:I used to have a pristine 182 that hangared with us and it had the VG's on the top of horizontal. The other day I saw him sanding on his tail. Turns out the airplane went through 5 annuals before anyone realized they were on wrong all that time. Wonder what he paid for that snafu.
I almost feel sorry for your buddy, almost...![]()
Sorry but that is just too hilarious, 5 years you say??!
...or just pencil whipped the owner's "annual".Apparently the IA who's been signing it off all these years has never seen a set installed?
L-19 wrote:Apparently the IA who's been signing it off all these years has never seen a set installed?
mtv wrote:Maybe it'd be wisest to put them where the manufacturer said works best.....just a thought.![]()
L-19 wrote:I'm sure they would work find there.... But whats the purpose? You think your experiencing air separation on your trim tab? I would think putting them UNDERthe horizontal would fix your problem, but I havent heard of a kit for just the tail? Better elevator effectiveness would mean using less trim than you are using currently correct?
I have a brand new set in a box in the hangar, waiting to go on my GCBC as soon as it's on land. From all reports I've heard it will make a noticeable improvement.
172heavy wrote:It a possibility, the trim becomes less effective at lower speeds, I was thinking that there may be separation there, I never run out of elevator, but if I use all of my trim its still not enough, and it approaches unmanageable on a go around, I realize that I’m trying to compensate for a forward CG. I was curious if anyone had tried it and if it made a difference or not. And how effective are they on the rudder? Will I be able to get more yaw on a slip? Ultimately a proper CG is the answer.
Not sure I'm following this. My P172D is a bit nose heavy, too (Lycoming conversion), and full aft trim is not quite enough if I'm trying to maintain a very slow airspeed approach, like 55 mph. But that just means I have to have some back pressure on the yoke. If I have to go around, I have to shove the yoke and retrim right away--but I don't think that has a thing to do with any separation at the trim tab. I think it just means that the tab is at its lower limits in its effort to raise the elevator (tab goes down, elevator goes up). On the go around it's necessary to overcome the tab's efforts by shoving the yoke forward and retrimming to avoid a "trim stall"--and if the tab was more effective, it would require just that much more of a shove and quicker retrimming. All of this is normal, in any airplane that uses a tab for pitch trim; adding VGs to the tab alone, if it did anything at all, would exacerbate the effects of trimming and increase the need to shove hard and retrim on a go around.but if I use all of my trim its still not enough, and it approaches unmanageable on a go around,
If you really need more AFT elevator authority on a tail with a trimtab, you'll want full "NOSE DOWN" trim set.
Sounds counter-intuitive, but it sets the tab way up high, and give you a bit more ooomph when you pull back.
