Here is my AOA/AOS gauge from a different angle. From here, you can clearly see both arrows reading the relative airflow (wind) at the same time. The rod is at the same angle as the wing (cord) and is pointing the same direction as the airplane's nose. You'll see when I use left and right aileron (no rudder input) we get quite a pronounced adverse yaw. You'll also see a stall where the AOA reading drops into the red. At the end, you'll see the landing where I'm lined up with the runway and you can see the relative wind (crosswind) coming from the right. At the last moment, a crosswind gust pushes the plane to the right before touchdown.
This indicator can be useful for new pilots and others to directly see and understand their AOA and sideslip angle based on the relative wind. I believe it may even be helpful in reduce the number of stall/spin accidents.
https://youtu.be/lY3eGZSun6A
