Battson wrote:All I know is you need to choose the right wax. I think silicon based products are the enemy, you would want to check it out yourself.
Otherwise fabric repairs can be a real problem because the covering system paints / coatings won't stick to the old paint.
This is one of the biggest myths in aviation. Any wax or sealant will make it harder to have things stick, because that's exactly what they are designed to do. They are also easy to remove with things like dish soap. So put 2oz in your emergency repair kit and clean the area that you need to tape before you make the repair.
Want empirical evidence?
The single most commonly recommended airplane treatment is Pledge. We think our stuff is better, because we don't leave a film behind to look a bit worse and collect dirt and dust more quickly, but the reality is that Pledge is *extremely* common. What's the active ingredient: Dimethyl Silicone Oil
