Fri Jul 02, 2021 12:08 pm
I've flown a Cessna 170 with Flint tanks (installed inside the outboard end of the stock wing) and a Cessna 206 with the wing tip tanks (which are added onto the end of the stock wing.
With those tanks full, the airplane feels a LITTLE bit more ponderous in flight, but not that much. The procedure Flint recommends is to run one main down, then switch to the other main, and pump from the tip tank into the main that you have partially drained. Then, after running the other main down some, you again switch tanks and pump some fuel out of the other tip into that main.
It's a bit of monkey motion, and requires that you actually actively manage fuel, which a lot of Cessna pilots don't really do.
But, I've pumped one main down and pumped the entire tip tank into that main, to see how much control input you have to hold due to the weight differential. It's noticeable, but not unmanageable.
The thing I LIKED about the Flint system is that if I didn't NEED the extra fuel, I just left the tip tanks empty and operated off the mains. Only down side is a little more weight.
But, with the connected Monarch tanks, if you put gas in them, that fuel is spread out between both tanks on each side.
Same goes for contamination. The Flints are separate from mains, so if one or the other is contaminated, the other MAY not be.
