FWIW, we do all our DPTs with te engine hot. So I don't think there's any concerns with removing plugs when hot. Same goes for installing.
Jeredp wrote:I don't have much to offer in the way of advice but I'm sure impressed with your stick-with-it on this issue. You're learning valuable things and getting intimate with your toy. That impresses me! Keep after it, sure a nice looking bird!
CamTom12 wrote:Pop quiz: how many hours would you guess this oil has on it?
8GCBC wrote:CamTom12 wrote:Pop quiz: how many hours would you guess this oil has on it?
Can you give us a hint...Total Time Since Overhaul/Top?
CamTom12 wrote:8GCBC wrote:CamTom12 wrote:Pop quiz: how many hours would you guess this oil has on it?
270 SMOH
hotrod180 wrote:CamTom12 wrote: Did some maintenance today, pulled and cleaned all the plugs and reinstalled them in the same cylinders, but swapped bottoms and tops.....
FWIW here's a diagram of how Champion suggests rotating the plugs.
Something to do with polarity of the spark, and extended electrode life.
CamTom12 wrote:Z was a lot closer, there's just less than 17 hrs on that oil. That's a hot sample, too.
I thought it coated the side of the glass well and although it looks a little dark to me I think it's doing ok. Purely an eyeball inspection though. I'm going to change it early this time for another blackstone labs sample. Shooting for about 30 hours on the oil for the next sample. The last sample had 50 hrs on it.
StampCreek wrote:hotrod180 wrote:CamTom12 wrote: Did some maintenance today, pulled and cleaned all the plugs and reinstalled them in the same cylinders, but swapped bottoms and tops.....
The mags are spinning opposite each other on the gear train so the spark on one will propogate spark plug tip out and the other will go outside in. Wears the center electrode differently. So yeah, swap top to bottom and left mag to right mag. Or bottom to top and right to left. You get it.
