Backcountry Pilot • What adhesive for vinyl interior items
10 postsPage 1 of 1
after scouring the interior of the new bird, the only "gripe" I can find is that the glue which holds some of the interior pieces in place is coming loose. Not a big deal but I'd like to take action now to keep it from progressing further and becoming a big deal. Any recommendations on what substance to use to stick this stuff back in place?
Window trim stbd
window trip port
trim trim :lol:
Straydog offline
FindMeSpot URL: https://maps.findmespot.com/s/6KPK
Aircraft: Stinson 108-1/220
Re: What adhesive for vinyl interior items
Contact cement. Can get it in spray cans.
NimpoCub offline
Best stuff going...
www.avthreads.com
I'm a big fan of dap weldwood landau contact cement, and have a few gallons just around the corner from you at KSZP. I'm out there most Wednesdays and Thursday, your welcome to drop in and grab some if you like.
Jim
boyfalldown offline
+1 on the 3m stuff. Used in STC's.
lesuther offline
+2 on the neoprene adhesive, industry standard in aircraft interior shops. All the airplanes I built for Kenmore were done with that stuff.
Sam
Halestorm offline
Aircraft: C-182E Pponk
bigrenna wrote:Best stuff going...
+4 and sometimes 1300L
Never had to stick vinyl aircraft interiors BUT, Polyvinyl chloride is PVC, no matter where it is, and I have had excellent results sealing and sticking PVC using pvc pipe glue from the hardware stores. It actually solvent welds it together, better than any incompatible interface adhesive system. It can be purchased in a clear solution other than the usual grey, which make it invisible when dried. PVC is chemically the same no matter if its been formed into rigid pipe, soft tubing or vinyl Naugahyde . It's modulus of elasticity is controlled only by the amount of plasticizers infused into it's basic formula.
Sidewinder offline
Duct tape. Ten million rednecks can't be wrong.
BTW Straydog, it's time to change your avatar to reflect your new airplane.
Thanks a bunch for the recommendations folks, I think I'll follow the numbers on this one and get some of the 3M stuff.
Jim-I'm at SZP pretty frequently, I'll PM you my info lets get together some time.
hotrod180 wrote:it's time to change your avatar to reflect your new airplane.
Indeed it is, I'll get crackin on that :)
Straydog offline
10 postsPage 1 of 1
