mtv wrote:If you use Iso Propyl alcohol in your fuel, any water in your fuel will remain liquid, and therefore can be sumped. Doesn't anyone here use fuel additives in cold weather?
ington6 wrote:I got into a bad habit of not sumping my tanks every time I take off but after hearing some stories I am going to change my habits immediately. What other things do you guys check religiously before take off? Im on a 182. Any other checks particular to a 182 that I should make an every time check?
Nosedragger wrote:Good info on this thread. I'll add one I haven't seen yet: If I'm parked outside for a few days I now check for wasp nests in my fresh air vent tubes. I almost had a bad experience after leaving my plane on the ramp for a three day weekend at Dillon Mt. The little buggers moved in fast and I didn't see the fairly obvious nest even though I checked the pitot a few feet away. I flew it home on a cold day without opening the vent but on a warm day or or a sweaty aproach I normally yank the vent open, which is just above eye level. A herd of hornets in the mush on short final would suck!
blackrock wrote:Last year landing at Cabin Creek with Bobby, CU, and DeadStick Steve. There must have been 200 mosquitoes in the Cabin when I took off. What a distraction; but what in the hell do you to get red of them? Opening the windows in flight helped a little. Next time, the windows stay shut when on the ground:!:
Ridge Runner wrote:Self, Weather, Plane
Self- On the way to the aircraft hangar, I do a brief self-assessment. Am I tired? Hungry or thirsty? Distracted by non-flight related issues? Am I mentally prepared for focusing on flying the plane? If any of these issues are present, they need to be resolved before I get into the aircraft.
Weather- How is the weather looking now? What is the visibility? What is the forecast for wind and visibility? If windy or gusty, am I prepared to fly in less than ideal conditions? What are other pilots reporting? Do I really want to fly in less than ideal conditions today? If cross wind is 25 mph or greater, flight is canceled. If visibility is less than a mile and forecasted to be less than a mile, flight is canceled. If rain, hail, lightning, reported wind shear, microbursts, mini-tornadoes (like dust devil) or other poor wx conditions are reported, flight is canceled until weather clears up.
Plane - Starting from the tip of one wing, I work my way around the entire aircraft. I hand feel every AN bolt, confirm that there is a cotter pin in each castle nut, look for any tears in the fabric, shake the plane at each wing strut to test for looseness in each strut then aft to the tailfeathers. I move the tail back and forth by hand and observe any play in the tailwheel spring, open up the access compartment at the tailwheel and test the tightness of the tailwheel locknut (something I had to learn the hard way not to ignore), check tailfeather control surface linkages, rollers, cables, nuts and cotter pins, around to the other wing..then to the engine compartment, check plug wires, fan belt, air filter cleanliness, check for fluid leaks and fire hazards. Then I give the prop a good shake to check for looseness/vibration related issues, check each blade for damage, to make sure the metal leading edge tape is in the same place as it should be. Then I check the main landing gear for cracks or damage, then grab each wheel and trying to shake the plane back and forth to check for looseness or wobble on the hub (tighten if necessary), then check brake components (and recheck while taxiing).
Lastly, I take a clean rag with mild alcohol and clean the entire wing's leading edge, top part and flaps and ailerons. Then I center the stick and visually confirm that my vertical stabilizer is in line with the rudder. Then I check engine fluid levels, gas level in tanks, start the engine and let it warm up to normal low idle temp. Just prior to my first flight of the day, I will have an extra long engine rpm run-up, just to use some of the gas that has been sitting in the gas lines between what I can visually see (they're clear gas lines with clear in-line filters) and confirm that there is no air lock or material obstruction or hopefully no other issue. If there is an issue with gas, I want it to happen before take-off, not after. That's the main reason I have such a long engine run-up prior to a first flight of the day.
If all is well mechanically, then I check electronics, battery levels for radios, intercom, test comms, ignition redundancy, instruments, interior (anything loose, not tied down or un-necessary to be in the cabin?), turn on navs and strobe, check control surface movement, set flaps if wanted, advance throttle and go, testing brakes while taxiing.
GLASSPILOT said "Submit this post to the FSDO. You'll get a wings sign off AND a gold star. Say, do you ever actually make it to the flying part?"
I use these self-closing/self-opening pitot tube protectors. They work great.NOFATE said "Check the pitot for mud dauber nest. Learned this the hard way. If there is mud you have to take the pitot apart and blow the mud out from the backside."
Maybe something like this?
