1. When doing emergency landings, they are teaching to land straight ahead, with only a turn up to 30 degrees left or right. As a result, a point 2 counties away in front of the aircraft was selected despite the ample landing fields directly under the aircraft. Nearing the point of landing, multiple changes to the intended spot of landing had to be made to compensate for the actual glide. Which leads me to the next one...
2. Flaps are ONLY to be used if a steeper descent is needed. I couldn't believe what I was hearing. Despite the student repeatedly questioning the instructors (up to 4-5 of them) about this, all told him to not land with flaps. I posed these two questions: Do you land faster or slower with flaps? Are you going to get hurt more going faster or slower when you hit something? I followed this with a few paragraphs from Sparky's Mountain Flying Bible. After 3 botched simulated emergency landings, he made a real pretty one the following day after we talked about using flaps. So how do you think these new pilots will react when they loose an engine with the nose pointed to water with the only land behind them or worse, when in the mountains when the only chance you have is that one short meadow...that is low and to your 4 o'clock?
3. The instructor would not go up with him if the wind was over 10 knots. Now, solo is one thing, but personally, I feel that as an instructor you need to prepare your student for the mild extremes and expose them to strong winds, rough air, etc. when the opportunity presents itself. I think that they are doing a real disservice by not exposing their students to conditions that they will now have to face for the first time on their own.
4. We did some power on stalls. He recovered nicely from the first buffet of the stall. I said, "OK, now give me one and take it to a full stall." He said he had never done one before. Again, I believe in exposing a student so he will know what to do when he isn't coordinated and inadvertantly stalls it because he was trying to pick up his GPS that fell on the floor on takeoff. We did a few and he learned the value of being coordinated. He also learned how to level the wings with the rudder during the recovery when he wasn't coordinated.
Overall, the impression I got was that there is some bad instruction being given down there by inexperienced CFIs. I would be willing to bet that bad instruction has been passed down from instructor to student, who eventually becomes the instructor. Like I said, I was dumb founded when I heard what they are teaching. How about some of you Skypark guys swing by and enlighten them a little?
