Fri Feb 16, 2018 12:55 pm
Here a couple FARs:
§91.9 Civil aircraft flight manual, marking, and placard requirements.
(a) Except as provided in paragraph (d) of this section, no person may operate a civil aircraft without complying with the operating limitations specified in the approved Airplane or Rotorcraft Flight Manual, markings, and placards, or as otherwise prescribed by the certificating authority of the country of registry.
(b) No person may operate a U.S.-registered civil aircraft—
(1) For which an Airplane or Rotorcraft Flight Manual is required by §21.5 of this chapter unless there is available in the aircraft a current, approved Airplane or Rotorcraft Flight Manual or the manual provided for in §121.141(b); and
(2) For which an Airplane or Rotorcraft Flight Manual is not required by §21.5 of this chapter, unless there is available in the aircraft a current approved Airplane or Rotorcraft Flight Manual, approved manual material, markings, and placards, or any combination thereof.
From 91.203:
(b) No person may operate a civil aircraft unless the airworthiness certificate required by paragraph (a) of this section or a special flight authorization issued under §91.715 is displayed at the cabin or cockpit entrance so that it is legible to passengers or crew.
So, do you see anywhere in there that Experimental aircraft are exempted from these requirements? Nope...these all say Airplane or Rotorcraft, etc. That includes Experimentals.
Now, operating limitations: If your Experimental doesn't have operating limitations, as discussed above, they you can't legally fly over a densely populated area, for example:
(c) Unless otherwise authorized by the Administrator in special operating limitations, no person may operate an aircraft that has an experimental certificate over a densely populated area or in a congested airway. The Administrator may issue special operating limitations for particular aircraft to permit takeoffs and landings to be conducted over a densely populated area or in a congested airway, in accordance with terms and conditions specified in the authorization in the interest of safety in air commerce.
Now, for the pilot:
§61.3 Requirement for certificates, ratings, and authorizations.
(a) Required pilot certificate for operating a civil aircraft of the United States. No person may serve as a required pilot flight crewmember of a civil aircraft of the United States, unless that person:
(1) Has in the person's physical possession or readily accessible in the aircraft when exercising the privileges of that pilot certificate or authorization—
(i) A pilot certificate issued under this part and in accordance with §61.19;
(ii) A special purpose pilot authorization issued under §61.77;
(iii) A temporary certificate issued under §61.17;
(iv) A document conveying temporary authority to exercise certificate privileges issued by the Airmen Certification Branch under §61.29(e); or
(v) When operating an aircraft within a foreign country, a pilot license issued by that country may be used.
(2) Has a photo identification that is in that person's physical possession or readily accessible in the aircraft when exercising the privileges of that pilot certificate or authorization. The photo identification must be a:
(i) Driver's license issued by a State, the District of Columbia, or territory or possession of the United States;
(ii) Government identification card issued by the Federal government, a State, the District of Columbia, or a territory or possession of the United States;
(iii) U.S. Armed Forces' identification card;
(iv) Official passport;
(v) Credential that authorizes unescorted access to a security identification display area at an airport regulated under 49 CFR part 1542; or
(vi) Other form of identification that the Administrator finds acceptable.
and:
(c) Medical certificate. (1) A person may serve as a required pilot flight crewmember of an aircraft only if that person holds the appropriate medical certificate issued under part 67 of this chapter, or other documentation acceptable to the FAA, that is in that person's physical possession or readily accessible in the aircraft. Paragraph (c)(2) of this section provides certain exceptions to the requirement to hold a medical certificate.
That section goes on to note that under Sport Pilot regs, no medical is required.
So, as noted a couple times by others, your aircraft must have the following documents aboard at all times:
Airworthiness certificate
Registration
Operating Limitations (which may or may not be found in an AFM or POH)
Weight and Balance
The pilot must have in his or her possession:
A pilot certificate appropriate to the aircraft being flown
A government issued photo ID
A current medical, if appropriate to the operation/pilot
Again, nothing in the regs exempts an experimental aircraft from any of those requirements.
