Is it simply a wider taller footprint?
Mike
Zzz wrote:
At current time I believe the 10" wheels still use a 6" disc (actually 7.5" or so.) The possibility of being able to run a full 10" disc is a rumor I've heard (seen?) The braking power would be increased, which is a consideration for those 35's for those who really get in short.
whee wrote:Thanks for sharing the backstory Mauleguy.
Since your a machinist and have built your own wheels I'm curious; can you ballpark what it would cost to have a set of 10" wheels with bead lockers machined? I've been thinking about putting together some drawings of such a wheel and taking it to my local machinist. Based on past dealings I think I could get a set made for close to the same as a set of 10" wheels from ABI.
I think a set of one piece 10" bead locker wheels could work great to run those desser 31s tubeless. They'd also work with 29" Airhawks.
A185F wrote:Thanks for the information. Currently running ABW 29's but need something more suited to both pavement and off field operations. Also trying to balance this with weight. Thinking the 850x10's might be a good balance given the weight of the 29 Air Hawk's.
Mauleguy wrote:Whee, I did build my own wheels and also about 12 more sets for others before ABW started casting the 10" wheel. It was expensive to machine them from billet and Bill Duncan saw the writing on the wall that if he wanted to sell more tires he needed to cast the wheel. I charged 2500.00 for a set back then (2005) and today I would probably have to charge 3000.00
The advantage is I could make them lighter, the wheels I have on my cub weigh 7.5 pounds machined from billet and the cast wheels are around 10 pounds.
Battson wrote:whee wrote:Thanks for sharing the backstory Mauleguy.
What do you mean by "with bead lockers machined", Whee? I would have just modified an existing wheel with a drill...
Or are you thinking of machining in space for an o-ring to seal the two halves so you can run tubeless? I looked into that, but you need purpose built wheels with enough meat left at the joint for the o-ring to fit into.
The other option I thought of was an RTV or paper gasket, but that's not solid design...
whee wrote:Mauleguy wrote:Whee, I did build my own wheels and also about 12 more sets for others before ABW started casting the 10" wheel. It was expensive to machine them from billet and Bill Duncan saw the writing on the wall that if he wanted to sell more tires he needed to cast the wheel. I charged 2500.00 for a set back then (2005) and today I would probably have to charge 3000.00
Awesome. Thanks Mauleguy.Battson wrote:whee wrote:Thanks for sharing the backstory Mauleguy.
Yeah...I worded that very poorly. I'm talking about a wheel that is one piece with a bead locker. If I had a set of 10" wheels I could modify them to add bead lockers but since I don't why not have a set of wheels made. A local machinist I've deal with on some jet boat stuff is about $60/hr. Based on my perceived complexity of a wheel vs the past projects I ballparked 10hrs per wheel. $500/wheel for material (10" diameter 12" long extrusion). $60/hr x 10hr + $500 = $1100/wheel; pretty much the same cost as a 10" ABI wheel but my estimate could, and likely is, way off.
Tire install would be the same as shown in this video:
Crzyivan13 wrote:2014 on my way to Idaho. Loaded to damn near gross (minus 12 gal of fuel). I didn't check air pressure in the tires before i left. First landing was on a concrete runway in Indiana. The wheel "chirp" was more of a low screech. I knew at that moment i had spun the tire on the rim.
26" Goodyears on 6" wheel. 8 psi i was guessing. Worked fine lightly loaded. Not so much with a load.
I marked them when we mounted them up.
You can see the angle of the valve stem.
Got lucky and just let some air out and spun it back around.
