SE6601KF wrote:Point is.
Why risk dicking up your expensive aircraft wheels with some chemicals?
You can bead blast in about 5 minutes.
No chemicals to try to get rid of.
Clean up with an air hose.
Prime then paint.
Some Chemicals?? It looks like your from Alaska, not California
Alkali cleaning solutions are not deleterious to Magnesium alloys, and not to the environment either, and won't cause cancer in unborn mice.
but they can't be beat for removing ground in organic material in the nooks and crannies that could be worked into the surface if not removed before or after bead blasting.
As for etching. reading the above pdf file states that nitric and hydrofluoric are some of the preferred acids and you don't have to be from California to appreciate that hydrofluoric acid is very nasty stuff to work with.
Edit: Aluminum can be one of the more difficult materials to coat. Just because it looks good just after painting doesn't mean its gonna stay that way. Preparation is the key. Clean clean clean. No moisture, finger grease, dirt or oxidation. Items should be handled with a fresh pair of disposable gloves after cleaning. and then coated asap.
