Backcountry Pilot • Wheel Spats for C170/180/185/205/206/207
9 postsPage 1 of 1
I need your help to decide if I should get this STC.
When I completed the rebuild of my 1955 C170B, I installed a set of Cessna Wheel Spats that were optional equipment for the C188 AgPlane. Since then, I have had many owners ask about them.
They work as designed with tires up to 8.50 and are compatible with Federal AWB wheel skis. They have a total weight of 4 pounds. The fenders are made of a tough ABS plastic. There is a stamped metal frame bonded to the ABS fender for strength. An upper and a lower bracket clamp to the gear leg. The design is such that a cotter’d pin allows for 3 minute removal of the fenders while leaving the clamp in place on the gear leg.
They have no effect on measured cruise speed in my C170. They work perfectly to prevent water, mud, grass, debris and cow shit from spraying up and soiling the underside of the wings, fuselage and tail.
I think it might be possible to also design and incorporate as an option a ‘rock guard’ that would provide added protection to the tail from stones being kicked up by the tires.
Early estimates of cost to produce and STC the kits would put them at about $3000 for a set.
Please tell me if you think this is something you would buy at that price if it were produced and approved?
Thank you,
John Nielsen
john54724 offline
John Nielsen
Co-Owner
www.Flight-Resource.com
Re: Wheel Spats for C170/180/185/205/206/207
Hi John,
I would not.
-DP
They look really nice, but I am afraid there are many other places I would put that sort of $$ into my plane before them. Sorry:(
daedaluscan wrote:They look really nice, but I am afraid there are many other places I would put that sort of $$ into my plane before them. Sorry:(
X2
John,
These are almost ubiquitous in Alaska Cessnas: http://www.aerotwin.com/products/main_g ... ctors.html
And they work well. Not as pretty, but they protect the tail, which those on your 170 don't without significant modification. Aero twin pricing for these gravel deflectors is $1900, and they are STCd
Sorry John. $3k seems a bit steep... plus I think of the cow shit under my wings as a badge of courage. I have "vintage" shit from last season still up there. #-o
Thanks for bringing it up though! Looks cool.
www.avthreads.com
They do look nice though.
Hoeschen offline
Aircraft: 1956 C182, 2014 RV-9A
If they could be aerodynamically improved to fill the low pressure behind the tire reducing drag and showing an increase in speed while protecting the aircraft and keeping it clear you could have more interest. I would like to go faster with bigger tires.
Skydive206 offline
Mike,
I was not aware of the ones you showed on the link. Thank you. That is exactly why I LOVE this group...If you can not get help here, it is not available anywhere!!
I will dig into how these would attach to a flat gear of a C170 or 180 or 185. Mine do not have a rock guard flap.
There is still 'nicely aged cow shit' inside of mine also :)
Production costs would need to come down a lot in my opinion to be viable...but continue to provide your feedback and ideas please.
john54724 offline
John Nielsen
Co-Owner
9 postsPage 1 of 1
