Wed Dec 23, 2015 12:36 pm
Interesting comments. Yeah, there's a risk--just getting in the airplane is a risk. SE IFR is a risk anywhere, but with 4000' to glide in the clouds to roughly 9000' bases, then roughly 2000' from the bases to the ground until over the higher terrain, there's lots of time and visual room to make a plan. My airplane has a bit better glide ratio than the average 172, which I suppose has something to do with the droopy tips and flap gap seals, plus I can pull the prop out all the way to reduce drag, so there are a lot of possibilities if something goes wrong. Believe me, I don't go into any of that lightly, without thinking of the risk and how to mitigate it to the extent I can. It's the same thought process whenever I go into the rocks in good VFR weather, i.e., if something happens, can I put it down somewhere and survive?
FWIW, the route east of Durango to Alamosa is V211 BRAZO V368 ALS with an MEA of 13,000'. If there'd been a hiccup, the first alternative would have been to turn around back to Durango depending on where the hiccup occurred. Otherwise, there are Jicarilla/Apache Nation and several private strips west of the bigger rocks, all pretty usable. Once over the top, it's gliding distance to Alamosa. On east of Alamosa, the MEA is 14,000', and there are Fort Garland on the west side of the rocks and Cuchara Valley (La Veta) and Spanish Peaks (Walsenburg) on the east side. The only real issue is invariably a mountain wave effect that creates a real sinker after La Veta Pass. But the terrain allows a steady emergency glide into the low lands if necessary.
Incidentally, I watched the leading edges on the way through the clouds to on top, and there was never a trace. I think it was too cold, but whatever, there wasn't any. I had the pitot heat and AOA heat on, of course, but the only frost was on the inside of the side windows, and not much of that.
Honestly, I'm concerned a whole lot more about flying over the Denver area, especially on the usual VFR routes from Greeley either east or west of the Bravo to Centennial or farther south. There aren't a lot of safe places to put it down while over that urban area.
Anyhow, I wanted to share some of the views--it's truly beautiful from up there, although it was pretty cold outside, -6 to -8 F until after we descended north of Pueblo. Fortunately the heater works well and kept the interior in the low 60s, and both puppy dog and I were dressed for the cold. All in all, it was a really good trip.
