As I've posted previously, after years of being an aviation nerd I'm finally in the early part of ground school and flight lessons for my PPL. My goal is to become a safe backcountry pilot.
There is a ton of information. Some I can tell is important, some I can tell I just need to memorize for a short time.
Example of important ground school stuff:
- if you fail to return the gas cap to the right position during pre-flight you can lose all your fuel.
- very common error is a stall/spin on the turn to short final because of slow speed, sharp turn and pilot focused on the runway instead of the turn
- density altitude
- carb ice
- load factors
Example of not-so-important ground school stuff:
- IFR minimums for helicopters
- cabin pressurization
- properties of the atmosphere
My inclination is to push through ground school quickly and focus on the stick and rudder stuff but as I get a bit older I've come to realize my haste has not always served me well. So my question to the experienced backcountry pilots: If you were to go back and start again, are there areas of study where you wish you had paid more attention or has most of your knowledge come from experience?
