Backcountry Pilot • Which Aircraft Fits My Mission?
46 postsPage 3 of 31, 2, 3
Re: Which Aircraft Fits My Mission?
mtv wrote:From the perspective of a CFII, I'll offer this suggestion:
You're trying to do too much with one airplane. You're going to need a fairly well equipped airplane for the instrument training, and for the Commercial, you're going to need either a TAA or a Complex aircraft. Your $30K plane isn't going to meet any of those criteria.
SO, Buy a good "starter airplane", that's VFR only, but in reasonably good shape. The best you can find for your price point. A Pacer or early 172 or?? fits this price range.
Now, do your IFR training in a rental. You can't operate your own airplane for $75 an hour. So, use the FBO airplane for that. In the meantime, you're building time on YOUR schedule in your own airplane toward the Commercial, which is going to require total time. ALL the time as PIC counts towards that.
Then, when you're ready to prep for the COMM, find another rental, or use the school plane if it's TAA qualified. You'll need ten hours in that and you'll have to take the checkride in it.
All the while, you'll be building time in your personal plane. May take a little longer, but the point is, NO $30K airplane is going to even come close to what you want to do.
Take advantage of that $75 an hour rental.....Seriously, that's a DEAL!
I will chime in to agree with MTV and also offer one correction to his post. Since the change in complex to complex/TAA, the checkride does not have to be in that airplane. After you have the required 10 hours of complex or TAA, you can take the commercial checkride in any airplane, it does not have to be complex or TAA. So you could do the commercial checkride in your own airplane or in the school IFR machine. A flight school I have spent time at went from having their commercial checkrides in a C182RG to using that for the 10 hours and then having the checkride entirely in C150s or 7GCBCs or C172s or whatever.
Troy Hamon offline
Aircraft: Piper PA-22
Troy is correct. My daughter just did her Commercial checkride in my C180 after getting her 10 hours complex in a Comanche 250.
lcdrles offline
Aircraft: Cessna 180
Maule M5 180C
CT_Pilot wrote:
stolkid94 wrote: Still looking for any info of the Aero Commander Lark 180.
Curious about the Lark as well. Has anyone in here flown one much? Wondering how they perform as far as short field take offs & landings, and climb rates.
The Helio Courier is a Legendary Aircraft with tales of It leaping off of the ground. There is a MAJOR problem with them and it is parts. With only 500 total planes ever built parts are becoming a problem. The later Helios are even worse with only 17 or 18 ever made. Yes you can get parts but they are expensive! In the past year there has been some beautiful low time late planes for sale and they are not selling.
The lark is an okay airplane but who is going to buy it when you are done. Nobody is going to spend 50k on a lark when they can buy a 172, 170 or a Maule. The Cessna And Maule parts are plentiful, lark not so much.
Quickdraw1 offline
lcdrles wrote:Troy is correct. My daughter just did her Commercial checkride in my C180 after getting her 10 hours complex in a Comanche 250.
Yep, I'm showing my age. Forgot the new ACS policy on that. My bad.
And, actually, even in the old system, you just had to do "Some" flight during the checkride in a complex. I knew one examiner who'd do one takeoff and landing in the complex, then switch to whatever other airplane you wanted to finish the comm. maneuvers.
lcdrles wrote:..... My daughter just did her Commercial checkride in my C180 .....
=D> =D> =D>
G44 wrote:
That might work. The seller could give it to you for free then you could dump about 30 to 40k into overhauling the engine and all the other stuff you will discover when you dive into it, maybe more then you will have a ho hum hard to sell airplane worth about $5,000 less than what you have into it and that is if you got it for free. I know you think you are “handy” due to your job in the Army but there are many experienced A&P mechanics that wouldn’t even consider some of the projects you consider or ask about. I realize you are just learning and are asking questions but finding a sound airplane that wont need much except for some simple cosmetic stuff would be the best way to go. Fixer uppers are not the money saving airplanes they may appear to be unless you REALLY know what you are doing.
Yeah, makes sense. I just didn't know anything about the lark and was having trouble finding info on it. Figured I'd ask. I also found out the empty weight is stupidly high.
lawndart offline
