tedwaltman wrote:I have the WWA-210 with the WWA-P920 governor on my Super Cub. Seems great. Good, prompt, customer service. No complaints.
Hoeschen wrote:Ran one on an RV, wonderful prop and the nickel leading edge looked like brand new after 250 hours
WWhunter wrote:Tom,
Here is a partial explanation that a guy posted on another site:
"Whirlwind aviation and whirlwind propellers.
2 deferent companies . Whirlwind propellers , which mine is {"GA200L 78" & 18lbs and 20 min. adjust time} and whirlwind aviation like Goza used ? [STOL 210G , &44 lbs and FAST adjust time], but they used to be one company and then split.
WW aviation makes certified props, mostly constant speeds but also make the VERY good ground adjustable STOL G210 , & WW propeller makes only exp. props none of which are constant speed so a lighter hub but can not be converted to a constant speed.
WW propeller does make props for 912s and all kinds of exp , airboats & even make blades for the M14P Russian radial , if they can make a blade that hold up to these beast I am not worried on my 0320 . If I understand it right WW propeller still makes the blades for WW aviation ? BUT my blades are NOT the same design as the STOL G210 that Goza and others like so well. "
