Sat Jun 16, 2012 11:13 am
Well, we decided to go with the Whirlwind on my brother's S6S and so far so good. The prop took about two weeks to be delivered, was well packaged, and all parts were included (but more on that in a minute). We also got their 11.3 inch carbon spinner which was finished very nicely and ready for paint.
As we began the install process, we realized that the included hub mounting bolts were going to be too short, since the s6 has a prop spacer and also uses nuts on the back of the prop flange instead of threaded inserts ( which also means we didn't need to use the included wave lock washers). A quick trip to town for some 5/16-18 x 4" socket head bolts and some grade 8 nylocks and we were back in business. The spinner and backing plate were painted last night, and then everything got assembled is morning.
The recommended initial blade pitch of 17 degrees was too flat, and resulted in almost redline static RPM. 19 degrees seems just about right, about 5400 static, 5500 on climbout, and close to 5800 full throttle in cruise (our field elevation is 4840').
Anyway, compared to the ground adjustable 2 blade sensenich that this prop replaced, it is much smoother. No so much mechanical vibration wise, as the sensenich was a smooth prop, but there is much less (really none) drumming from the windscreen and skylight, and it is quite a bit quieter inside and outside. We've only got a couple hours on it so far today, but so far it seems like a great prop. We need to do some more testing for cruise speed comparisons, kind of squirley air this morning.
Without the spinner or backplate this prop weighs 8 pounds, one pound lighter than the 2 blade sensenich.
Pretty excited about this prop, it's going to make the flight up to JC on Wednesday a lot more enjoyable. See you all in a few days!
Ted
