seward wrote:I have a 1962 C182 with original windows and will be taking a long trip with a friend soon. He wants to take photos out the pax window, which looks pretty bad. My pax window does not open. Given we want to keep costs low, what would be the advice for best replacement window plastic? A deep bubble window? shallow bubble window? Flat window similar to current one? Clear, or tinted? Any suggestions would be welcome.
Do you mean that it literally doesn't open at all? Not even a couple inches like the ones I've flown. Because if it does open even a little bit I've heard rumors that you can remove that one screw and open it all the way. That's the right solution from a photographic standpoint.
The bubbles will distort, but are surprisingly inexpensive. (surprising to me anyway. I bought a Maule partly because Cessna parts are so expensive, but this part looks damn reasonable!
http://www.glapinc.com/Cessna/182/c-182b.htm#bubble)
The flat ones will be better, but will be surprisingly expensive for a piece of acrylic.
Another possibility to avoid shooting through crummy windows is to mount a gopro on the strut and trigger it with the keyfob remote.
Not sure why you would even consider tinted from a photographic standpoint. Best case scenario is that the exposures will be longer and have more motion blur, worst case is that they will have a tint that cannot be removed without skewing the color of the photo.
