Wing height on amphibs
Looking for the wing height of Cessna 185/206 on amphibs. Putting a mezzanine in a hangar and need to make sure the wing will fit underneath.
Thanks in advance
akgreg offline
484
- Aircraft: Yes
Mon Aug 17, 2020 10:36 am
Howdy Keith,
I have all that info. I’m hoping someone will actually put a tape measure on one and see. My guess is that it will be slightly different than calculated. It’s right up there with people who say their plane weighs X, when it really weighs Y when put on a set of scales. Seeing is believing.
Cheers
akgreg offline
484
- Aircraft: Yes
I don't have a number for you, but I can tell you it's a LOOONG way to fall.
10515
I don't have a number for you either but one other consideration is that the wing will move up quite a ways if the strut (I know that some models of floats use rubber donuts) or tire on the opposite side were to go flat. Just a consideration.
bat443 offline
431
I was definitely taking that into considering.
I’m guessing that you know it’s a long way to fall based on previous experience eh Mike?
akgreg offline
484
- Aircraft: Yes
Wipaire had a 206 that they measured for me. 10’1” for anyone interested. Probably not.
akgreg offline
484
- Aircraft: Yes
Wed Aug 19, 2020 10:40 pm
185 on Aerocets, just off the jacks during annual, light, so fully extended main gear. 11’0” at the wing tip. 11’4” to the tops of the com antennae.
Pinecone offline
996
- Aircraft: Cessna A185F
Thu Aug 20, 2020 10:51 pm
akgreg offline
484
- Aircraft: Yes
