Backcountry Pilot • Winter pre-heating
Winter pre-heating
66 postsPage 4 of 41, 2, 3, 4
Re: Winter pre-heating
fshaw wrote:What cowling cover are you guys using?
Thanks.
Frank
Mine are Kennon. I bought them through Reiff 12 years ago, but had I known that Kennon was the manufacturer, I would more likely have bought them direct from Kennon. I have bought a number of other items from Kennon (cowl plugs, pitot and AOA probe cover, windshield cover, window sunshields, wing covers). All good quality, and superb customer service. If I had to replace any of them, I'd contact Kennon again.
Bushveld wrote:Thanks for the feedback folks. Point taken on the insulated covers. I don't see myself being out during subzero Fahrenheit conditions, unless a hot tub or sauna are available. Personal minimums and all. :)
At the risk of pointing out the obvious, you're going to need a much larger generator to power those.
rw2 offline
Aircraft: Experimental Maule
Thanks.
Frank
I'm using artic covers. Made in Winnipeg. They were great to deal with and seem to be great quality so far.
David
For preheating at base I have been having good success with the Quad Hornet model produced by these folks: http://www.aircraftheaters.com/. It seems to be of quality construction, has a solid warranty, is thermostatically controlled and designed to be plugged in and left in your engine compartment continuously (though I don't use it that way). The night before I fly I stick it in the rear of the engine compartment in my J-3, bundle the whole thing up with a moving blanket or two, cover the prop, and come back in the morning to a toasty warm power plant. The Quad is probably over-sized for my C-85, but I like that I can show up the morning of and have a preheated engine within a few hours (about the amount of time it takes me to convince myself that I want to go flying in a drafty Cub in sub-freezing temperatures). By the way I have nothing to do with the manufacturer. Just a satisfied customer.
Felix offline
Contributing author
Aircraft: 1946 Piper J-3C Cub
1953 Piper L-21B
1957 Cessna 180A
Felix wrote:For preheating at base I have been having good success with the Quad Hornet model produced by these folks: http://www.aircraftheaters.com/.
Thanks for the link. I might have to give their big one a try in my aircraft cabin.
PAMR MX wrote:Flyboy-ak has a heated hanger. Don't believe any of his "bush pilot" stories of winter flying. [emoji3]
I see the smiley, but for the record I kept my planes outside and flew regularly for 39 years before getting the means to have a heated hangar. There are not many that have flown in as cold as I have done for recreational fun. One has to be very prepared, careful and knowledgeable to fly below -25F, and it exponentially gets more difficult at -30F, -35F and -40F. Coldest I have taken a cold-soaked plane and flown in the same ambient is -44F, and it was a bit scary. You have to have the gear to survive in that cold, cause machinery gets all kinds of unreliable beyond -30F. I will be following the IronDog, Ultrasport and Iditarod races this year in the plane, but so far we have had a very mild winter and no deep cold. Looking forward to it. :-)
Flyboy_AK offline
Aircraft: Highly Modified PA-12
Users browsing this forum: No registered users and 29 guests
