C182DPhreak wrote:New member looking at an old thread. Apologies up front for the noobie approach, but I'm similarly looking for one of the "not available" spinner domes for a '61 C-182D. Based on the age of some of the previous posts, it looks like I missed out on the earlier deals. Anyone else out there with a "saw in a hangar" or "found in a barn" story of one in good shape? My current spinner dome on a McCauley prop model number 2A34C203/90DCA-X (I think it's a -8) looks like it came off a totally different airframe; it's functional but just doesn't "look right" for the airframe so I don't think it's the D-7519-1 part number associated with the actual prop. Appreciate any response, cat calls, "what a dope" replies...
So what does it look like? If it's the really rounded dome spinner like the ones pictured above it is the original Cessna spinner 0752004 which is the correct spinner for the 2a34c203.
If you have a longer pointy spinner with an internal plastic forward support it is most likely the D7519-1 which is also the correct spinner for the 2a34c203. These were installed per a McCauley propeller STC. The prop is on the type certificate but that spinner is not. The STC covers it but it could also be called a minor alteration.
All that said without knowing exactly what u got.
