Backcountry Pilot • WW II story
WW II story
9 postsPage 1 of 1
WW II story
Piggyback Hero
by Ralph Kenney Bennett
Tomorrow they will lay the remains of Glenn Rojohn to rest in the Peace Lutheran Cemetery in the little town of Greenock, Pa., just southeast of Pittsburgh. He was 81, and had been in the air conditioning and plumbing business in nearby McKeesport. If you had seen him on the street he would probably have looked to you like so many other graying, bespectacled old World War II veterans whose names appear so often now on obituary pages.
But like so many of them, though he seldom talked about it, he could have told you one hell of a story. He won the Air Medal, the Distinguished Flying Cross and the Purple Heart all in one fell swoop in the skies over Germany on December 31, 1944. Fell swoop indeed.
Capt. Glenn Rojohn, of the 8th Air Force's 100th Bomb Group was flying his B-17G Flying Fortress bomber on a raid over Hamburg. His formation had braved heavy flak to drop their bombs, then turned 180 degrees to head out over the North Sea. They had finally turned northwest, headed back to England, when they were jumped by German fighters at 22,000 feet. The Messerschmitt Me-109s pressed their attack so closely that Capt. Rojohn could see the faces of the German pilots. He and other pilots fought to remain in formation so they could use each other's guns to defend the group. Rojohn saw a B-17 ahead of him burst into flames and slide sickeningly toward the earth. He gunned his ship forward to fill in the gap. He felt a huge impact. The big bomber shuddered, felt suddenly very heavy and began losing altitude. Rojohn grasped almost immediately that he had collided with another plane. A B-17 below him, piloted by Lt. Wil lia m G. McNab, had slammed the top of its fuselage into the bottom of Rojohn's. The top turret gun of McNab's plane was now locked in the belly of Rojohn's plane and the ball turret in the belly of Rojohn's had smashed through the top of McNab's. The two bombers were almost perfectly aligned -- the tail of the lower plane was slightly to the left of Rojohn's tailpiece. They were stuck together, as a crewman later recalled, 'like mating dragon flies.'
Three of the engines on the bottom plane were still running, as were all four of Rojohn's. The fourth engine on the lower bomber was on fire and the flames were spreading to the rest of the aircraft. The two were losing altitude quickly. Rojohn tried several times to gun his engines and break free of the other plane. The two were inextricably locked together. Fearing a fire, Rojohn cut his engines and rang the bailout bell. For his crew to have any chance of parachuting , he had to keep the plane under control somehow..
The ball turret, hanging below the belly of the B-17, was considered by many to be a death trap -- the worst station on the bomber. In this case, both ball turrets figured in a swift and terrible drama of life and death. Staff Sgt. Edward L. Woodall, Jr., in the ball turret of the lower bomber had felt the impact of the collision above him and saw shards of metal drop past him. Worse, he realized both electrical and hydraulic power was gone.
Remembering escape drills, he grabbed the handcrank, released the clutch and cranked the turret and its guns until they were straight down, then turned and climbed out the back of the turret up into the fuselage. Once inside the plane's belly Woodall saw a chilling sight, the ball turret of the other bomber protruding through the top of the fuselage. In that turret, hopelessly trapped, was Staff Sgt. Joseph Russo. Several crew members of Rojohn's plane tried frantically to crank Russo's turret around so he could escape, but, jammed into the fuselage of the lower plane, it would not budge. Perhaps unaware that his voice was going out over the intercom of his plane, Sgt. Russo began reciting his Hail Marys.
Up in the cockpit, Capt.. Rojohn and his co-pilot 2nd Lt. William G. Leek, Jr., had propped their feet against the instrument panel so they could pull back on their controls with all their strength, trying to prevent their plane from going into a spinning dive that would prevent the crew from jumping out. Capt. Rojohn motion left and the two managed to wheel the huge, collision-born hybrid of a plane back toward the German coast. Leek felt like he was intruding on Sgt. Russo as his prayers crackled over the radio, so he pulled off his flying helmet with its earphones
Rojohn, immediately grasping that crew could not exit from the bottom of his plane, ordered his top turret gunner and his radio operator, Tech Sgts. Orville Elkin and Edward G. Neuhaus to make their way to the back of the fuselage and out the waist door on the left behind the wing. Then he got his navigator, 2nd Lt. Robert Washington, and his bombardier, Sgt. James Shirley to follow them. As Rojohn and Leek somehow held the plane steady, these four men, as well as waist gunner, Sgt. Roy Little, and tail gunner, Staff Sgt. Francis Chase, were able to bail out.
Now the plane locked below them was aflame. Fire poured over Rojohn's left wing. He could feel the heat from the plane below and hear the sound of 50 cal. machinegun ammunition 'cooking off' in the flames. Capt. Rojohn ordered Lieut. Leek to bail out. Leek knew that without him helping keep th e control s back, the plane would drop in a flaming spiral and the centrifugal force would prevent Rojohn from bailing. He refused the order.
Meanwhile, German soldiers and civilians on the ground that afternoon looked up in wonder.. Some of them thought they were seeing a new Allied secret weapon -- a strange eight-engined double bomber. But anti-aircraft gunners on the North Sea coastal island of Wangerooge had seen the collision. A German battery captain wrote in his logbook at 12:47 p.m.:
'Two fortresses collided in a formation in the NE. The planes flew hooked together and flew 20 miles south. The two planes were unable to fight anymore. The crash could be awaited so I stopped the firing at these two planes.'
Suspended in his parachute in the cold December sky, Bob Washington watched with deadly fascination as the mated bombers, trailing black smoke, fell to earth abou t three miles away, their downward trip ending in an ugly boiling blossom of fire.
In the cockpit Rojohn and Leek held grimly to the controls trying to ride a falling rock. Leek tersely recalled, 'The ground came up faster and faster. Praying was allowed. We gave it one last effort and slammed into the ground.' The McNab plane on the bottom exploded, vaulting the other B-17 upward and forward. It slammed back to the ground, sliding along until its left wing slammed through a wooden building and the smoldering mess of came to a stop. Rojohn and Leek were still seated in their cockpit. The nose of the plane was relatively intact, but everything from the B-17 massive wings back was destroyed. They looked at each other incredulously. Neither was badly injured.
Movies have nothing on reality. Still perhaps in shock, Leek crawled out through a huge hole behind the cockpit, felt for the familiar pack in his uniform pocket pulled out a cigarette. He placed it in his mouth and was about to light it. Then he noticed a young German soldier pointing a rifle at him. The soldier looked scared and annoyed. He grabbed the cigarette out of Leak's mouth and pointed down to the gasoline pouring out over the wing from a ruptured fuel tank.
Two of the six men who parachuted from Rojohn's plane did not survive the jump. But the other four and, amazingly, four men from the other bomber, including ball turret gunner Woodall, survived. All were taken prisoner. Several of them were interrogated at length by the Germans until they were satisfied that what had crashed was not a new American secret weapon.
Rojohn, typically, didn't talk much about his Distinguished Flying Cross. Of Leek, he said, 'in all fairness to my co-pilot, he's the reason I'm alive today.'<
Like so many veterans, Rojohn got unsentimentally back to life after the war, marrying and raising a son and daughter. For many years, though, he tried to link back up with Leek, going through government records to try to track him down. It took him 40 years, but in 1986, he found the number of Leeks' mother, in Washington State. Yes, her son Bill was visiting from California. Would Rojohn like to speak with him? Some things are better left unsaid. One can imagine that first conversation between the two men who had shared that wild ride in the cockpit of a B-17. A year later, the two were re-united at a reunion of the 100th Bomb Group in Long Beach, Calif. Bill Leek died the following year. ;
Glenn Rojohn was the last survivor of the remarkable piggyback flight. He was like thousands upon thousands of men, soda jerks and lumberjacks, teachers and dentists, students and lawyers and service station attendants and store clerks and farm boys who in the prime of their lives went to war.
He died last Saturday after a long siege of sickness. But he apparently faced that final battle with the same grim aplomb he displayed that remarkable day over Germany so long ago. Let us be thankful for such men.
Amazing story, thanks for posting it, brought tears to the eyes. I'm proud to be in the service they created for us.
/salute Capt Rojohn and all those fine men.
Good story :!:
That is a great generation of men. I respect them and thank them for my freedoms.
Great generation of women too. They built those tough old airplanes here at home.
Bill
Flat Country Pilot offline
Flat Country Pilot
Farm Field PVT
54 170B
I was lucky I didn't have to go through any of that. I respect those that did and take my hat off to them. Those of us that missed serving owe those that did. As I have said many times We enjoy the same freedoms, as those that did and they picked up the tab. I can't thank those men and women enough. Thank you, Thank you. A great story by the way. Bob
skybobb offline
Will Rogers 1879 - 1935
Poor Sgt. Russo. Being 5'3" I know where my station would have been had I lived in that era and been assigned to one of those planes. Glad I live today. Glad those guys lived then. I'm going to shake quite a few hands in the next life.
svanarts offline
A very well told story.... Thank You for that.....
My dad had quite a time too... He was a tail gunner in a B-17 that was shot down over Germany. He bailed out, survived 9 mos. in German POW camps and being force marched over 1100 miles. He went in the service weighing 185 lbs. and came home at 115 lbs. They made em tough in those days....
Even through all that, though, he brought home a love of flying that he never forgot.
I thank God for him and each and every one of those brave men and women, for what they have given us.
Coyote Ugly offline
Track My Spot
Coyote Ugly wrote:I thank God for him and each and every one of those brave men and women, for what they have given us.
Amen, and I believe our job is to not forget
a64pilot offline
Re: WW II story
I enjoyed your post. I would like to share one more. My daughter sent me this email this morning. It is from a friend. She forwarded it to me, partly because her husbands grandfather was belly gunner in a B 17 in WW II, her own grandfather recently passed and was one of those landing at Omaha beach on D Day and fought through the Battle of the Bulge in a badly out gunned tank destroyer and her brother, my son is a marine currently serving in Iraq. I hope the pictures come through of the B 17 and German fighter.
Look carefully at the B-17 and note how shot up it is - one engine dead,
tail, horizontal stabilizer and nose shot up.. It was ready to fall out of
the sky. (This is a painting done by an artist from the description of both
pilots many years later.) Then realize that there is a German ME-109 fighter
flying next to it. Now read the story below. I think you'll be
surprised.....
[cid:3333602809_228720]
Charlie Brown was a B-17 Flying Fortress pilot with the 379th Bomber Group
at Kimbolton, England. His B-17 was called 'Ye Old Pub' and was in a
terrible state, having been hit by flak and fighters. The compass was
damaged and they were flying deeper over enemy territory instead of heading
home to Kimbolton.
After flying the B-17 over an enemy airfield, a German pilot named Franz
Steigler was ordered to take off and shoot down the B-17. When he got near
the B-17, he could not believe his eyes. In his words, he 'had never seen a
plane in such a bad state'. The tail and rear section was severely damaged,
and the tail gunner wounded. The top gunner was all over the top of the
fuselage. The nose was smashed and there were holes everywhere.
Despite having ammunition, Franz flew to the side of the B-17 and looked at
Charlie Brown, the pilot. Brown was scared and struggling to control his
damaged and blood-stained plane.
BF-109 pilot Franz Stigler B-17 pilot
Charlie Brown.
[cid:3333602809_204923] [cid:3333602809_218041]
Aware that they had no idea where they were going, Franz waved at Charlie to
turn 180 degrees. Franz escorted and guided the stricken plane to, and
slightly over, the North Sea towards England. He then saluted Charlie Brown
and turned away, back to Europe. When Franz landed he told the CO that the
plane had been shot down over the sea, and never told the truth to anybody.
Charlie Brown and the remains of his crew told all at their briefing, but
were ordered never to talk about it.
More than 40 years later, Charlie Brown wanted to find the Luftwaffe pilot
who saved the crew. After years of research, Franz was found. He had never
talked about the incident, not even at post-war reunions.
They met in the USA at a 379th Bomber Group reunion, together with 25 people
who are alive now - all because Franz never fired his guns that day.
(L-R) German Ace Franz Stigler, artist Ernie Boyett, and B-17 pilot Charlie
Brown.
[cid:3333602809_221622]
When asked why he didn't shoot them down, Stigler later said, I didn't have
the heart to finish those brave men. I flew beside them for a long time.
They were trying desperately to get home and I was going to let them do
that. I could not have shot at them. It would have been the same as
shooting at a man in a parachute.
Both men died in 2008.
This is a true story http://www.snopes.com/military/charliebrown.asp
<http://www.snopes.com/military/charliebrown.asp><http://www.snopes.com/mili
THIS WAS BACK IN THE DAYS WHEN THERE WAS HONOR IN BEING A WARRIOR...THEY
PROUDLY WORE UNIFORMS, AND THEY DIDN'T HIDE IN AMBUSH INSIDE A MOSQUE, OR
BEHIND WOMEN AND CHILDREN, NOR DID THEY USE MENTALLY RETARDED WOMEN AS
SUICIDE BOMBERS TO TARGET AND KILL INNOCENT CIVILIANS...HOW TIMES HAVE
CHANGED......
BFLYNBYU PPC'S, L.L.C.
Brent L. Boggs
221 Hungerford Avenue Haysville, KS. 67060
316.260.0575 Cell Shop/Home/Fax 316.529.4696
[email protected]
<http://us.mc828.mail.yahoo.com/mc/[email protected]><http://us.mc8
N840BB
look closely........ the details make the difference.
Integrity, safety, redundancy - worth every penny!
------ End of Forwarded Message
dirtstrip offline
Re: WW II story
Good story. Steve
steve offline
Aircraft: 1980 Cessna 185F
9 postsPage 1 of 1
