0-300 question
Hey you 0-300 conti gurus. Is it possible to put an angled starter drive from a D model onto a B model so I can run a vacuum pump?
Thanks
David
5186
Thanks Jered. I'm curious if te whole accessory case needs to be changed or if the angle drive just bolts on. As far as I can tell, they are the same cases. Only differences are the 8 vs 6 bolt crank flange and the angle drive starter adaptor.
5186
Not possible.
I know the rear case is different. The main case may be different also.
behindpropellers offline
135
- Aircraft: C206 & Cub
behindpropellers wrote:Not possible.
Ok. Thanks for the info.
5186
4557
- Aircraft: Old Clunker
Just looked at my logs, I have a 337 stating that the case was replaced with with a d model case, generator replaced with alternator, and vaccum pump installed. Hope this helps. If you need more info, I can dig deeper.
Jeredp offline
625
- FindMeSpot URL: http://share.findmespot.com/shared/face ... 7NYN40QT2I
- Aircraft: Cessna 172
Jeredp wrote:Just looked at my logs, I have a 337 stating that the case was replaced with with a d model case, generator replaced with alternator, and vaccum pump installed. Hope this helps. If you need more info, I can dig deeper.
Case as in accessory case or the complete crank case?
5186
A1Skinner wrote:Jeredp wrote:Just looked at my logs, I have a 337 stating that the case was replaced with with a d model case, generator replaced with alternator, and vaccum pump installed. Hope this helps. If you need more info, I can dig deeper.
Looks like the case, not accessory case:
Jeredp offline
625
Jeredp wrote:A1Skinner wrote:Jeredp wrote:Just looked at my logs, I have a 337 stating that the case was replaced with with a d model case, generator replaced with alternator, and vaccum pump installed. Hope this helps. If you need more info, I can dig deeper.
Thanks Jered!
5186
Thu Dec 01, 2016 11:50 am
I know a guy with a 170B which has a belt-drive vacuum pump--
it mounts in front of the #5 cylinder.
Needs a 172-style nosebowl however.
What's wrong with a venturi?
Simple, never needs an overhaul...
if it ices up you've probably got bigger problems to worry about.
Main drawback IMHO is gyros don't spin up until a minute or two after takeoff.
Maybe a Garmin G5 would be a worthwhile mod.
10534
Thu Dec 01, 2016 12:05 pm
hotrod180 wrote:I know a guy with a 170B which has a belt-drive vacuum pump--
The plane is already set up for a vacuum pump. And as nice as a G5 is, it does not meet requirements night flight in Canada. It is on a 172.
It's moot really, I've found out the a B model engine is not certified on the mid 60s 172. So I'm on the hunt for a D model now.
5186
Continental gave guidance on how to convert one model O-300 to another O-300.
I'd talk to someone at TCM to get a copy of that.
http://www.tcmlink.com/pdf2/maintenance ... x30014.pdfThe O-300 IPC Shows a different part number for the accessory case for the O-300-D
Bagarre offline
794
- Aircraft: 1952 Cessna 170B project
