0-320
Fri Jan 02, 2009 11:29 am
Does anyone have a first time runout or low time 0-320 for sale? Thanks.
96chevtruck offline
10
Fri Jan 02, 2009 11:45 am
Ive got two one is almost run out,not sure if its first time. and a mid timer that runs great and doesent burn oil. bolth are narrow deck. the better one is in Idaho right now wating to be picked up. PM me if interisted.
River rat offline
749
Fri Jan 02, 2009 11:57 am
I have one sitting on the front of my RV-6 O-320-E2D that has a 100hrs SMOH on it I might be talked out of, I am thinking about converting to an IO-360
It had 2068TT on first run before it was overhauled and fuel pump added.
What are you putting it in
mr scout offline
774
Fri Jan 02, 2009 12:34 pm
Try barnstormers.com and put Lycoming in the search engine or click on it in the column. Tons of stuff.......
1285
Sat Jan 03, 2009 11:51 am
I got a first run 0-320-E2D that I will be removing from my 172 for an 0-360 conversion. Total time is approx 2800 hr. Will be complete with starter and mags. Also the prop will be for sale. Engine is running good but it is tired. Compression at the last annual was 66/80, 62/80, 68/80, 70/80. Burns a quart every six hours. Contact me if you are intrested
Nick
Swingwing offline
33
