180Marty wrote:Been awhile for this thread but went back and read my Dec 29th post and........Sure glad you figured it out and let us know.
It's happened on 2 engines I know of in the last year. Both about 600hrs on them. They weren't as lucky as you and had major failures in flight. Thank fully no injuries. Rebuild sheets didn't show new retaining clips. Builder got POed and sent lawyers after the shop that dissected the engines rather then figuring out if they actually had an issue or not... I will no longer recommend those engines.NWestern180driver wrote:180Marty wrote:Been awhile for this thread but went back and read my Dec 29th post and........Sure glad you figured it out and let us know.
Yeah you definitely called that! The engine shop I’m planning on using said it’s not a common occurrence. Have you had it happen before? $20 in parts leading to a engine failure..
180Marty wrote:..... I think I read that at overhaul the first thing you do is remove and discard those snap rings on the counterweights....
180Marty wrote:Never heard of it before but from the symptoms you described it seemed like a possibility. I think I read that at overhaul the first thing you do is remove and discard those snap rings on the counterweights never to be used again. Will the crank be able to be used again assuming it was good otherwise?
