feedpro wrote:EGT readings do not matter unless extremely high and there is a major difference between cyl. EGT readings are used for establishing peak egt when leaning. They are monitored for difference between cylinders which can be an indication of problems. Balance between cylinders is not easy to achieve in a carb engine because of intake leaks. There is a lot of information out there, so google Mike Busch of Savvy Aviation.
My information comes from over 5000 hours behind Avcom conversions in a 170B and two 175 tail wheel conversions and I never cared what the egt gauge said, only the changes it made based on what I was doing with the mixture.
