182/206 Heavy Duty Wheel Pants
My 182H had the option of 8.00x6 mains, with the 6.00x6 nose wheel, and I'm planning on upgrading to those sizes. I already got the 206 fork, axle, etc. I likely will leave the wheel pants off, but thought it would be nice to have a set of the heavy duty oversized pants that I could put on the plane if I wanted. I recall that they were pretty common on the 206 through the 60s & 70s also. I was just curious if anybody knew of a set getting dusty in a hanger somewhere.
Lance
Hman442 offline
101
- Aircraft: Cessna 182H
Sierra Victor offline
338
- Aircraft: Cessna T206H
In all honesty, either go pants or not. Leaving the backing plates on can lead to trouble. I've seen a few things bent up because they got rocks caught in there...
5186
Fri Apr 27, 2018 12:39 pm
That's a good point. I was just thinking that bigger tires and pants would kind of be the best of both worlds, unless a guy got in the gumbo
mud !
Hman442 offline
101
We just put some on a customer's 206. The pants are so wide that we have to build quite a large fill plate. Even with that in, I can't see them making very much difference. But they did fit over the 8.00 no problem.
5186
A1Skinner wrote:We just put some on a customer's 206. The pants are so wide that we have to build quite a large fill plate. Even with that in, I can't see them making very much difference. But they did fit over the 8.00 no problem.
Were the pants new and if so who did u buy from? Cessna prices are cray cray [emoji12]
338
Sierra Victor wrote:A1Skinner wrote:We just put some on a customer's 206. The pants are so wide that we have to build quite a large fill plate. Even with that in, I can't see them making very much difference. But they did fit over the 8.00 no problem.
No he had found them used somewhere. May have even been off a piper...
5186
