Backcountry Pilot • 182 vs 206 nose fork/strut
7 postsPage 1 of 1
Looking for some help here. Wondering if anyone knows if there is a difference between a '73 C182 nose fork/strut and a '69 nose fork/strut? Looking specifically for the standard fork, not the HD.
Thanks in advance.
David
Re: 182 vs 206 nose fork/strut
David,
Pull the parts manuals and compare part numbers. My guess is the inner piston and fork are the same.
behindpropellers offline
Aircraft: C206 & Cub
Standard fork that is for a 500x5 wheel and tire are the same on a just about all the 100 series and 200 series non retractable nose wheel airplanes. Off hand I cannot think of any that are different. A lot of the tubes were of different length.
behindpropellers wrote:David,
Parts manual shows different numbers. I dont have a standard fork from a 206 to compare to the 182 one that I have, hence then question.
The 182 and 172 show different numbers too, but they look identical...
qmdv wrote:Standard fork that is for a 500x5 wheel and tire are the same on a just about all the 100 series and 200 series non retractable nose wheel airplanes. Off hand I cannot think of any that are different. A lot of the tubes were of different length.
Tim, thanks. Tires are the same, but are the forks the same that you know of?
Thanks.
Thanks.
I have never seen a different fork from 150, 152, 172, 175, 182, 205, and 206. Not sure about the not retractable 177 Cardinal
Take a walk around a busy airport and take a look at all the forks. The early early fork did not have little gussets cast int the fork. They did that a bit later. I have only seen one fork without the gussets. Most were changed out.
Thanks.
Thanks Tim. That was our idea as well. I kno from the 150 to the 182s all look the same. Just can't find part numbers to back that up. All my parts books list fork/strut assemblies, or fork kits. But none list just the standard fork number.
Thank fo the help guys.
David
7 postsPage 1 of 1
