1959 T182 ? should I add Sportsman/VG's?
bushwagon wrote:Question for those with the Sportsman STOL and VG's. Are the VG's mounted to the Sportmans STOL or set back? I would like to do both mods eventually but would probably just do VGs in the near future.
Good question, I was wondering the same thing because I would also like to do both mods eventually. I guess the Sportsman should be added first.
3263
- Aircraft: 1957 C-180A
Micros vg's(wich I think are preferred) are mounted forward. If you have the Sportsman kit, they will be on it. I think there is another company making vg's that you can put on a 180 that mount farther back on the wing. I was told they weren't as effective. I have the micros and am happy with them.
shortfielder offline
2350
- FindMeSpot URL: http://share.findmespot.com/shared/face ... D263l9HKFb
Rob
Your plane is the perfect candidate for a sportsman, and yes, Micro vg's go on top of the sportsman cuff. Only thing you'll lose is decent angle. It increases the glide angle especially on a 170.... but that's what the flaps are for. I haven't flown a 170 with both, but the sportsman alone is quite a boost.
oldtech offline
138
Airspeed, Altitude, Brains. You need 2 of the 3!
The Oldtech
Sat Jan 08, 2011 10:18 pm
oldtech wrote:Rob
I'm still getting used to the 170.... Seems like it drops like a rock with 40 degrees of flaps compared to my Dad's Cessna 120 that I was used to flying.
3263
Pulled my Wing x extensions yesterday from my 206 with the Sportsman. Wont need the extra performance for a couple of months and want to get it out of the weather and into a cheaper T hanger. At the light weight I couldnt tell any performance difference.
Skydive206 offline
551
