Be carful when loading and unloading the float compartments on Wipaire 2100 floats. The hydraulic lines and fittings are exposed. I must of bumped the "down" hydraulic fitting and it started leaking. Just a slight turn of the wrench (9/16") resealed the connection. Test flew and OK now.
The top line is to the "down" actuator:
About a cup of 5606A leaked into the bottom of the float compartment:
Filled hydraulic reservoir and cycled gear with electric power pack and hand pump. The system is self bleeding which is nice:
