Figure with all the weight on the nose, it's a good time to move some weight aft as well. Strobe and ELT were located behind the baggage bulkhead so took the entire assembly and moved it back one more bay. Combined that with adding some extended baggage.
Drilling more holes in the airplane
- 153742936_10222136739705406_3668203103945056437_n.jpeg (75.84 KiB) Viewed 3798 times
Adding the new support to match the previous one we had.
- 154273098_10222144367056085_1758844835934878372_n.jpeg (199.98 KiB) Viewed 3798 times
Still a little wiring cleanup but that should work well. Also took the time to install nutplates instead of using nylocks to hold everything down to make it easier in the future to remove stuff if needed. Hate having to reach underneath with a wrench, especially when you are balanced on a skinny piece of wood in a tiny cave.
- 181788239_10222617786331271_2523161885979284262_n.jpeg (266.43 KiB) Viewed 3798 times
Last, we need to figure out how to dress the headliner, but digging the extra space.
- 184706455_10222674546110230_4925948906797713002_n.jpeg (257.98 KiB) Viewed 3798 times
