What he ^^^ said. Correct Fuel pressures are essential on these engines, and not every mechanic knows how to set them up.
Secondly, when you talk about the point where the electric pump kicks in, I assume you’re discussing the use of the electric pump with the switch on low boost? That’s the switch position which has a mechanical connection to throttle position. The high boost (red rocker switch) sets the electric pump to high speed continuous, and is limited to five minutes.
The following has nothing to do with your problem, probably, but it’s essential to understand the function of the fuel pumps in these airplanes, so a review:
The engine driven fuel pump runs at speed (and flow) dictated by the engine’s rpm. Simple: higher rpm, more flow.
The electric pump, on the other hand, has THREE speeds only:
Low boost, with yellow boost switch on and throttle between idle and about 2/3 open. This position allows the engine to run at or close to idle in flight if the mechanical pump fails.
Medium boost, with yellow rocker on and throttle open. This speed works continuous and is designed to keep the engine running if the mechanical pump failed, and you’re in flight.
And High boost, with red rocker switch On. This position permits the engine to make max power with the mechanical pump inop.
The reason for the five minute limit on the high boost position is a cooling issue. That pump gets REALLY hot when run high boost. Which is also why the switch is spring loaded. Look at the location of the electric pump....it gets and needs a lot of cooling.
My priming procedure for first start of the day is: Master on, Energize yellow rocker switch...low boost, and listen to the sound of the electric pump. Now, push throttle to wide open, and listen for pump speed increase. Now, momentarily energize high boost (Red rocker switch), and listen for higher speed of pump.
Now, throttle to idle, boost off, and start. This procedure verifies all three speeds of the boost pump are available. If the mechanical connection between the throttle and boost pump is disconnected, in this condition, if the mechanical pump fails (rare, but happened once to me....over Shelikof Straight ten miles from shore), you will only be able to run engine at cruise power using the emergency speed of the pump (red rocker) and they only guarantee the pump for five minutes at that speed.....
I know, more information than you want....and you likely already know, but....
