Backcountry Pilot • 74R, Horizon Airport, TX
9 postsPage 1 of 1
Gotta make a run to Lackland AFB in Sept to watch a grandkid graduate from basic. Never been to San Antonio, and in looking at the map, this "seems" like a nice grass airport, and close to the base. Unless I can help it, for this trip I'm going to avoid big city airports of any kind.
Any local info is appreciated. Thanks.
Re: 74R, Horizon Airport, TX
Not sure I can help you with the airport thing. But make sure you make time to go to Rudy's Country Store and BBQ in Leon Springs (it's the original of the Rudy's BBQ and IMHO, the best BBQ in the country). It's right off of I-10 west of town (I think around exit 550).
Their "Moist Brisket" is like eating candy :P :P
You're welcome to stop by 2F0.
It is paved, but it's small town. We also have fuel at a decent price.
If you let me know when, can fix you a home cooked meal and some cold beer.
Mercifully Free From the Ravages of Intelligence
wtxdragger offline
Aircraft: 1989 Maule M7-235
1948 Cessna 170
I base my plane out of 5C1 northwest of SA. I have flown into Horizon several times and the grass runways are in pretty good shape. The two things to be careful of are that that it's in a cutout for the class D at Stinson airport...keep your pattern tight. Second is it's right next to a shooting range...don't piss anyone off!
If you need the use of a vehicle and want to hangar your plane (and don't mind landing on nasty asphalt), you're welcome to fly into Boerne Stage. I have a newer standard shift jeep available, and also have a nice one bedroom apt in my hangar you're welcome to use. It's a longer drive to Lackland, but it's 5 min away from Rudy's BBQ in Leon Springs!
Tom
Tom S-7S offline
GumpAir wrote: Unless I can help it, for this trip I'm going to avoid big city airports of any kind.
While i totaly appreciate avoiding the big city airports, i used to fly down to San Antonio frequently and tried a varity of airports, but finally stuck with Stinson KSSF. The FBO (San Antonio Aviation) folks were excellent, always ready to help (got excellent deal on hotels and rental cars), came in before/after hours without any question (and without any charge) that it just made life easier. And for class D, very low key operation, and no fees. Otherwise Tom's offer sounds good. =D>
Chris
slowhawk offline
Take a look at Castroville. KCVB - Cheapest gas around. Great friendly airport and airport manager. Courtesy car, only 8 miles straight down 1 road to Lackland. Did I mention cheapest gas in the area?
jugheadF15 offline
Contributing author
Are you sure Lackland won't let you land there? If you call ahead and ask permission to land to attend the ceremony, they might well give clearance....The class Charlie airspace and all the AFBs (3 different fields) around San Antonio is fairly friendly but very busy, with lots of high speed T-38 and T-37 training going on the north east side of the city and heavy AC at SA intl and Lackland. I recommend flight following even if you skirt the Charlie airspace.
littlewheelinback offline
Thanks for all the great info and offers guys. Exactly what I was looking for.
We're gonna wander down from the wilds of Nevada with a couple Arizona stops to visit friends/family, and then planning on TX the 12th or 13th. Now kinda leaning towards Castroville. I like the ONE ROAD plan for nosing into the city. But knowing me, I'll make a final decision when I'm two minutes out, looking out the window.
As for Lackland itself... Unless something's drastically changed from how it was at other joint use bases, they're not gonna let civilian wheels touch their runway or ramp without a huge PIA hassle.
Manager: COMMANDING OFFICER
KELLY AFB
SAN ANTONIO, TX 78241
Phone 210-925-4883
Additional Remarks
E60-33 BAK-14 BAK-12A(B) (1705') HOOK MB100 (60' OVRN).
E60-15 RWY 15 BAK-14 BAK-12A(B) (1853').
- RSTD: ACFT WITH WG SPAN LARGER THAN 93' NOT AUTH IN ARM/DEARM PADS.
- CSTMS/AG/IMG: CSTMS, PLANT QUARANTINE AND IMG AVBL, CTC BASE OPS BY FONE PATCH OR PTD RDO 2 HR BEFORE ARR. ALL PERS, EXCLD ACTIVE US MIL, MUST CLEAR IMG INBD.
- RSTD: PPR (48 HR PN FOR ACFT RQR CUSTOMS/AGRICULTURE SVC), CTC BASE OPS DSN 945-6802, C210-925-6802.
- BEARING STRENGTH RWY 15/33 - ST175 SBTT590 DDT870 TRT580.
- TFC PAT: AETC ACFT EXP REDUCED RWY SEPARATION DAY. VFR-3000' BTN SIMILAR ACFT, 6000' BTN DISSIMILAR ACFT. VARIATIONS EXIST FOR DIFFERENT TYPE OPR. TRAN FTR ACFT MUST NOTIFY TWR ON INITIAL CTC IF REDUCED SEPARATION IS NOT DESIRED.
- SERVICE-LGT: RWY 15-33 PAPI/ILS RPI NOT COINCIDENTAL.
- JASU: (A/M32A-86D).
- FUEL: J8.
- FLUID: SP PRESAIR LHOX LOX LHNIT.
- OIL: O-133-148-156; SOAP - AVBL 2000-0600Z++ TUE-THU; 1230-2230Z++ FRI.
- TRAN ALERT: OPR 1200-0400Z++ MON-FRI; 1400-0400Z++ SAT-SUN, CLSD FEDERAL HOL, OT 2 HR PN RQR CTC BASE OPS. 1 HR PN RQR FOR ALL ACFT SVCG; CTC BASE OPS DSN 945-6802, C210-925-6802 OR PTD TO AVOID DELAYS.
- MISC: ACFT WITH CODE 6 AND ABV CTC BASE OPS FONE PATCH/PTD WITH BLOCK TIME AT LEAST 1 HR BEFORE LDG.
- SEE FLIP AP/1 SUPPLEMENTARY ARPT RMK.
- A-GEAR: BAK-12A(B) CABLES RAISED BY BAK-14 DEVICE O/R TO CTL TWR.
- MISC: OFFICIAL POINT OF OBSERVATION DOES NOT ALLOW A CLEAR UNOBSTRUCTED VIEW OF RWY. WX TECHNICIAN VIEW FROM N TO SE IS PARTIALLY OBSTRUCTED BY TREES, BLDGS, & HANGARS. TECHNICIAN RELIES ON COOPERATIVE WX WATCH WITH TWR. HIGH INTENSITY SECURITY LGTS HINDER ABILITY TO DETERMINE SKY COND AT NIGHT.
- RSTD: TRANS ACFT EXP 1 APCH, HOME STN ACFT HAVE PRIORITY. EXP 1 APCH TO FULL STOP LDG ONLY 1455-1545Z++ FRI DUR BMT GRADUATION.
- CIVILIAN OPNS MANAGED BY PORT SAN ANTONIO 0700-2300.
- CAUTION: PROBABILITY OF HYDROPLANING AT ALL SPEEDS ENTIRE RWY.
- CIVILIAN RAMP LCTD NE OF RY. ATLANTIC AVIATION GA RAMP ACCESS VIA TWY A1 (SEE MILITARY REMARKS FOR ADDITION INFO).
- FOR GENERAL AVIATION CTC FBO 210-921-6100 FOR SVC. FULL SVC, JP-8, ARINC 129.725 CALL 1 HR PRIOR TO DEPARTURE ON WEEKENDS.
- MISC: CIVIL OPS ONLY: USER FEE; CARGO PARKING CTC PORT OPNS C210-362-7838/7848.
- RSTD: QUIET HRS 0500-1200++ DLY DEP AND FULL STOP LDG ONLY.
- MISC: ALL MIL ACFT WILL USE TRAN ALERT SVC AND PRK ON MIL RAMP UNLESS APV/ARRANGED BY AFLD MGT TO PRK ON CIV RAMP.
- RSTD: FLT PLAN RQRD FOR ALL CIVILIAN FLTS OPERATING INTO/OUT OF KELLY FIELD ANNEX. FILE PORT AUTHORITY SAN ANTONIO IN REMARKS SECTION OF FLT PLAN. ASK FOR MILITARY & CIVILIAN NOTAMS.
- SERVICE-FUEL: CONTRACT FUEL FOR BOEING CO. ACFT ONLY. MIL ACFT MUST USE MIL SIDE FOR FUEL.
- MISC: ALL PAX CARRYING ACFT MUST CTC AMOPS VIA PTD RADIO AT LEAST 1 HR PRIOR TO ARR.
- PRIOR NOTICE REQUIRED FOR ACFT USING PORT AUTHORITY OF SAN ANTONIO CTC ATLANTIC AVIATION 210-921-6100 0800-2300.
- NS ABTMT: EXP TO EXECUTE CLSD TFC NO LATER THAN DEP END RWY. EXTN PAT NA UNLESS DRCT. EXP VFR TFC PAT TO THE W WHEN TFC IS LGT. ACFT ARR BTN 0500-1200Z++ EXP FULL STOP LDG. NO AFTER BURNER TKOF DUR THESE TIMES WO PRIOR COORD AND APVL.
- ANG: OPR 1345-2230Z++ TUE-SAT. PPR FOR USE OF ANG RAMP, DSN 945-5934, C210-925-5934.
- AFRC: PPR FOR USE OF AFRC RAMP, DSN 945-4330, C210-925-4330.
Though I guess a copy of my DD214 would impress the shit out of them, and they'd roll out a red carpet. :lol:
Hi Gump,
I had most of a day to kill in San Antonio recently and asked a similar question to the 170 guys. As it turned out all I did was tour the museum at Stinson field (it was ok, cheap enough at $4 entry fee) but some of the guys offered up some other suggestions that you might be interested in.
click here for link to discussion
kg offline
Aircraft: Cessna 180J
9 postsPage 1 of 1
