8.00/6.00 upgrade - 182F
Hey have any of you guys been directly involved with the installation of the 206 fork/block onto the standard 182 fork? I got the new fork and tires, got everything painted and dropped it off with my IA, but he was a little confused as to how to assemble it.
There are two bolt holes on my strut, a lower one for the fork, and an upper one for the linkage.
Also, is there a bolt size difference between the HD block and the standard linkage?
CParker offline
487
- Aircraft: 1979 TU206G
Sat May 02, 2020 10:04 am
I’ve been running about 30 PSI in the mains (my airplane is hangared on an asphalt strip) and 25 in the nose for the last 16 months. On and off of grass strips most every flight. No issues.
As to the installation, mine came assembled. So I’m of no help. Sorry.
Simpletom offline
11
- Aircraft: 66’ Cessna 182.
Curious to know what some see as real-world air speed loss is when running the 310 gear and bigger tire?
KFLGADAM offline
14
- Aircraft: Cessna 182F
Speed loss between stock tires with no wheel pants and the new larger tires was negligible, I didn't do any before and after analysis but I definitely didn't notice any change.
CParker offline
487
You wouldn't happen to have a copy of the paper work that says you can run a 700x6 in the HD fork would you?
opiejahn offline
2
- Aircraft: C-182Q
