makingmemories wrote:Is an STC required to install 8.50's on the mains of a Cessna 182B and is it legal for the owner, not an A&P, to do the work. Thanks for all the input on the Landis fork. The trouble with that STC is that the same tire size has to be run all around. Sure don't want an 8.50 hanging off the nose of the C182. Happy flying!
gbflyer wrote:You do not have to run the same tires all the way around with a Landis fork, honest. I know what the STC says, I have one right here. They issue field approvals all the time for tires still. There are many, many Cessna's flying around with a Landis fork, 8.50 nosewheel tire and 29" Airtracs or 8.50 X 10's on the mains. The big deal about the Landis fork is the $$$$$.
As to the 8.50 on the nose being "draggy", I have not noticed much of that on the 206. We lost about 3 knots in cruise from the 6.00 nose/7.00 mains to 8.50 nose/8.50X10 mains.
As to your question, I don't believe 8.50's are on the TCDS for the 182, I could easily be wrong but it would be easy to look up. If they were you'd have to get an A&P to change them, I do believe.
gb
182 STOL driver wrote:gbflyer wrote:You do not have to run the same tires all the way around with a Landis fork, honest. I know what the STC says, I have one right here. They issue field approvals all the time for tires still. There are many, many Cessna's flying around with a Landis fork, 8.50 nosewheel tire and 29" Airtracs or 8.50 X 10's on the mains. The big deal about the Landis fork is the $$$$$.
gb
One thing you need to do with bigger mains is bigger brakes - Double puck Cleavland's on my 56.
maulewaco wrote:Why would you need bigger brakes? You need bigger Balls or better pilot skills. Brakes are for taxi only. If you need them to slow down on the runway you may be outside the box and should just get a parachute to pull after touch down.
gbflyer wrote:Must be cocktail hour there on the West Coast.![]()
gb
gb
Matt 7GCBC wrote:Hey Eric,
I just went to send you a PM, but noticed the previous weren't open - so sorry to the rest of you for chatting in the post. Flew over your place outside of McCarthy in the 180 about a month ago and saw you wave. Thought to stop in, but the kids were hungry, etc. Nice little slice of heaven you've got. Maybe we'll meet in the future.
