patrol guy wrote:I have a couple of questions. I know there are lots of smart guys out here and besides I am lazy (looking up the regs).
Today, while running my pipelines, I set a personal all time record. I know you Alaska operators probably do this on a daily basis, but to me this is a lot.
In less then a two and a half hour period today, I ask for and got 7 Special VFR clearances into and out of tower controlled airport airspaces.
1. Since I’m flying in IFR weather, can you log SPECIAL VFR as IFR time???
2. I’m never near this high, but was told each time to maintain 2500 ft or less. Does this mean that I can go lower then my legal 500 ft minimum that is normal for pipline flying over cities?
I don’t expect either answer to be yes, but thought they were interesting questions that I wasn’t sure about.
Thanks,
1SeventyZ wrote:An additional question on topic, since I'm an instrument student: Special VFR weather minimums are basically 1 sm viz and clear of clouds, right?
Do Special VFR clearances get granted more or less often during busy periods? I can see it being a liability technically, having a guy flying around out there low and close, but it means the separation between craft can be less, helping to ease congestion, correct?
a64pilot wrote:SVFR min. varies by control zone although 1 mi. and clear of clouds is usual. Army helicopter min. was 1/2 mi. and clear of clouds. The weather min for rotary wing outside of controlled airspace is clear of clouds and airspeed to see and avoid if I remember correctly. A helicopter can legally fly outside of controlled airspace with his rotor in the clouds, skids in the trees and not be able to see 50 ft. There is an exception to the 500 ft. rule for helicopters if I remember right also. Rotor wing is a whole different world, I miss it. There is something really cool about being able to stop in mid air and look at something
a64pilot wrote:Svfr min can vary by control zones, the controlling agency sets the min. No I wasn't trying to say you get SVFR outside controlled airspace, just the rules are very different for helicopters
